Question about Craftsman Garden
Ybsxs 1901ve 275078
What spark plug does it need
2 Suggested Answers
SOURCE: Somebody gave me a Craftsman lawnmower with a
under the carb is a metal bowl. This bowl houses the carbs float attached to a needle valve. This valve is probably stuck open due to corrosion or dirt blocking the opening. You can remove the bowl with a half inch wrench and lower the bowl from the carb. Let some gas flow out of the needle valve and work the float up and down to help clear out the obstruction.
Push up on the float and see if the fuel flow stops. If it does you can put the bowl back on and see if it stops flowing out the primer bulb.
If it is still flooding you probably need to replace the float, and needle and needle seat. These are pretty inexpensive you can order them online *(ebay might even have them!).
You might want to clean the main jet too. You should get this carbs diagram to show you where the main is located.
Posted on Jul 09, 2010
Testimonial: "Leaking stopped but mower still would not start. Soaked carb in Gunk & the bowl gasket stretched, have ordered an overhaul kit. Research showed the mower model as 917.377240 w/ motor 128602 0304 E1 w/ Walbro 214661 carb. Kit # 692703 or 792383 Thx"
What is the carburetor # I need for a briggs and stratton 5.5 motor YBSXS.2051HF 274479
You will need to communicate with an outdoor power equipment dealer or a Briggs and Stratton parts supplier to find that out.
Sep 19, 2014 | Garden
Engine Family YBSXS.4652VB 274521 leaking gas
Needle valve not seating. Needs cleaning.
Jul 19, 2014 | Snapper Garden
Ybsxs 1901ve
part number 690610
May 25, 2013 | Garden
I need an owners manual for a Husky supreme lawn tractor 25hp family size # YBSXS.7242.vf
try going to the husky website and order one. if that doesnt work try looking on ebay
May 24, 2012 | Garden
B&S 7 HP motor, YBSXS.1901VE Starts very hard - then runs great.
Needs more fuel on start-up adjust fuel or choke more. RayC
Sep 03, 2011 | Garden
I have a old yard machine self propelled lawn mower 6.25 HP 21" cut briggs & stration eng. Family YBSXS 1901VC 27446 EPA phase 1. I need the cable that goes from the saftey bar to the gas...
I have found OEM part number 746-0552 on Ebay. This is for older units, say 1997 on. The cable is 49" in length. Here is a link to ALL the MTD brake cables on Ebay.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=MTD+brake+cable&_sacat=See-All-Categories
Yours is the MTD-White Outdoor Push Mower Brake Cable. # 746-0552.
We call this the deadman/brake cable. It allows a small brake pad to rub against the flywheel on the top of the engine while at the same time actuating a switch which shorts out the ignition current to the spark plug. An interesting and much needed device, right! Good luck. Hope this helps.
Jun 12, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Somebody gave me a Craftsman lawnmower with a B&S 7 HP motor, YBSXS.1901VE 275078, because he couldn't get it started. I put gas in and it ran out of the primer bulb so I replaced the primer bulb. Now...
Jul 09, 2010 | Craftsman Garden
Have a craftsman model :917.273621, with a briggs & stratton 24 hpohv...familyy;ybsxs.7242vf. will cut good for 30 minutes, then sputter and stall. I disengage blades, and pull out choke to keep it...
try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Jun 18, 2009 | Garden
Garden Logo
213 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
