Question about Poulan Pp1000e 7-inch Pro Lawn Edger Attachment
What is CW turning - Poulan Pp1000e 7-inch Pro Lawn Edger Attachment
Need a diagram of the distribitor cap for a 1987 Samurai 4x4
my guess is this question is,
i need the firing order. (did you remove it without marking wires?)
the cap order depends on who timed it last.
no matter you can find #1
turn crank to TDC #1 firing mark. at 0 degree mark.
if valve lash is loose on #1 then bingo, if not rotate CW one more turn.
now #1 is loose. valve lash.
next, look at the rotor that is #1
make the cap and wire #1`
now crank motor, see rotor direction? , most are CW.
but look at the rotor spin and take note of that.
if CW? then #3 wire is next CW , cap hole for wire.
then CW, 4 then CW 2,.
CW = clock wise.
did i guess your question./?
Apr 07, 2013 | 1987 Suzuki Samurai
How do u set the darb screws on a mac cat 839 chainsaw
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H jet needle CW until the engine starts to speed up. Correct adjustment is when the engine 4-strokes at speed unloaded, but 2-strokes immediately when cutting. Release the throttle and adjust the L jet screw CW for better idle, yet allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Nov 05, 2010 | Garden
Carby tune up air/fuel mixture screws how many turns in/out Idle screw turns in/out
Make sure the fuel filter, air cleaner, and muffler are not clogged. Turn both jet screws CW to stops (lightly), then back out 1-1/2 turns CCW each. This is a basic setting which should allow the engine to start and run. Allow the engine to warm up, then pull the throttle full on--it should be 4-stroking. Turn the H screw CW until the engine speeds up somewhat, but still 4-stroking. Proper setting is 4-stroking unloaded, but immediate 2-stroking when cutting. Release the throttle and adjust L CW until the engine runs fairly smoothly, yet allows the engine to 'follow-the-throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 07, 2010 | Garden
Adjusting the idle jets on a homelite super 2
'L' is the idle jet screw and 'H' is the full throttle screw. Make sure the air cleaner is not clogged. Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed up, but still 4 stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine keeps running. Hope this helps!
Jun 03, 2010 | Garden
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
Hard to start, and wont idle long.
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
May 10, 2010 | Garden
Can't locate driver cw 50
direct link for the driver is : http://ftp.casio.co.jp/pub/EZ-USB/download/en/CWup303W.exe click on it or paste it to ur browser then the download will start.
its the same driver for stated below CW-50/CW-75/CW-E60/CW-K85/CW-L300
Feb 18, 2010 | Casio CW 50 Thermal Printer
I own a McCullogh 610 Pro mac chain saw. Why does
Check the muffler to make sure that the spark arrestor screen is not plugged. Make sure the air cleaner is clean and not plugged. Turn both L and H mixture screws CW to stops (lightly), then back out 1-1/2 turns each. Warm up the engine, then open the throttle and turn the H needle CW until the engine speeds up, but still '4-stroking' but should immediately start '2-stroking' with light cutting. Release the throttle and adjust the L needle CW for fairly smooth idle, yet rich enough to allow the engine to 'follow the throttle' immediately when accelerated. Adjust idle speed CW until the chain starts to turn, then back off until it quits turning. Make sure the chain is being properly oiled and is adjusted for no chain droop, yet turns freely by hand. Hope this helps!
Dec 27, 2009 | Garden
How to find hidden menu on yeasu 857d
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Oct 21, 2008 | Radio Communications
What is the torq for the front wheel bearing on a 2002 f150 2wd
As odd as this is, this is how the Ford Manual specifies the procedure:
1.) While rotating rotor Clock Wise, tighten nut to 40 NM (30 Ft/lbs).
2.) While rot. CW, loosen 2 turns.
3.) While rot. CCW, tighten to 23-40 NM (17-24 Ft/lbs).
4.) While rot. CW, loosen 1/2 turn.
5.) While rot. CW, tighten to 2 Nm (17 INCH/lbs, NOT foot/lbs!).
6.) Install nut retainer & cotter pin.
Jul 27, 2008 | Ford F-150 Cars & Trucks
Poulan Pp1000e 7-inch Pro Lawn Edger Attachment Logo
19 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
