Question about One For All Televison & Video
Mainpower mps600e codes - One For All Televison & Video
What is the code of TCL tv using Mainpower universal remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
Apr 01, 2018 | Universal Televison & Video
Mainpower code
0037,0038,0031,0033. Check these codes. For more information, check these links. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Nov 17, 2013 | Televison & Video
E000990-0000
E990 Error in the waste toner shutter
0000 When the output of the waste toner shutter opening and shutting detection
sensor doesn't become "H" when it WMUPR period after the sleep returns after
eight hours or more pass, the door opening and shutting is detected or main
power switch turns on.
- Check that the drum unit is properly installed
- Replace the waste toner shutter sensor
Aug 30, 2012 | Canon iRC2380i
When switched on the machine display shows switch on mainpower off and on.
is this a chain saw???. you are in the chain saw forum.
Feb 07, 2011 | Garden
What is main power supply for a laptop?
I would say that is most likley the motherboard not the power supply and this is a pretty big job you would have to take the laptop apart if the laptop is under warrenty I would use it otherwise you would most likley be better off getting another computer unless you are very good at taking computers apart. You can go to HP website support and get repair manual and it will tell you how to take apart.
Dec 07, 2009 | HP Pavillion ZV6000 Notebook
I have a 32" lcd, it is getting power but has no picture and no sound. It will power up, but u have to unplug to turn it off. Any ideas???? Help
It sounds like the 5v standby circuit is working but the main controller board is having problem sending the signal to turn ON and OFF the mainpower supply circuits that supply the power to the rest of the set.
Nov 04, 2009 | Vizio VO47L 47 in. LCD TV
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Am having ricoh 1013 photocopier, and its giving an error message that "functional error,switch off mainpower and on"!
Low fusing temperature. Either the thermistor is bad or power supply board (unlikely). Service code can only be reset in service mode by a technician after problem is fixed
Mar 24, 2009 | Ricoh Aficio 1013F Copier
Televison & Video Logo
24 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
