Question about Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP
Tilt leaking down - Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP
  • 4 Answers
Low fluid in unit and air in the system raise all the way up put safety lever down remove fill plug and top unit off replace fill plug then cycle up and down 3 complete cycles raise back up check fill level again you may hear air leak out when removing fill plug if low fill again repeat this cycle until unit stays full this should fix the problem if not the pressure relief valve is faulty if there is no external leaks
Posted on Apr 27, 2014
My johnson 50 when in the up position it slowy goes down and there no oil leaks ps how much tilt fluid should be in it tilt cheers michael
Have a bad check valve somewhere in the system allowing pressure to bleed backwards through the system, should be able to hear it when the bucket is up in the air turn off the tractor and listen closely to the lines for a slight whining sound from the fluid leaking when it should be sealed
Oct 11, 2016 | Sierra Johnson/Evinrude Tilt and Trim Pump...
Up down Tilt switch doesn't seem to work. can hear solenoid clicking. If I keep pressing the tilt switch, it can barely activate but struggles and is intermittent.
I would guess the system has a leak and you got water inside the unit . they will not pump water worth a darn .
Oct 05, 2015 | Boating
Does not latch
The door latch must make positive contact with the under-counter latch lock. The machines position is critical when shutting the door. Make certain the tab on the counter is making proper contact, not too much forward or backward, or bent up or down too much. The other adjustments are the Tilt backward and adjustment of the levelers at the corners of the washer (lower right and left sides). A front tilt could cause water leaking, so be careful when adjusting up or down.
Mar 17, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Water leaking from machine after cycle is over
Sounds like the pump is leaking. Tilt the machine back and put two 2x4s under the front legs. Shine a light under the machine and use a mirror to see where the water is coming from.
To change the pump:
  1. Remove the two screws at the front right and left corners of the control panel. Tilt the panel back. Remove the 3 wire harness plug and the two gold clips on the right and left of the cabinet holding the cabinet to the back panel.
  2. Tilt the cabinet forward and remove cabinet.
  3. Locate the pump and remove the two hose clamps and the two clamps holding the pump to the front of the motor. Remove the pump.
  4. Install the new pump
  5. Reinstall the two hose clamps and the two clips holding the pump on.
  6. Reinstall the cabinet, the three wire harness plug and the two gold clips holding the cabinet to the rear panel.
  7. Tilt the control panel down and reinstall the two screws on each corner.
Your ready to do some more laundry.
Dec 31, 2009 | Roper RAS6233KQ Top Load Washer
How to service a tilt/trim on a 50 hp yamaha outboard. I think the fluid is low as the trim will leak back down after raising the engine.
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Aug 31, 2009 | Boating
1987 Saab..top won't go up or down without help. Can hear the motor running but no movement. Can manually pull or push.
sounds low on oil, may have a leak, resivor under back seat, undo 2 torx screws tilt outward, fluid level line on resivor, ck for leaks on side rams w top down.
Aug 25, 2009 | 1987 Saab 900
140hp johnson seahorse tilt will raise the motor
it needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
Jun 20, 2009 | Boating
1992 150hp merc black max and hydraulics won't work, sounds like a sick animal.
On the bottom of the trim/tilt cylinder there is a big white slotted head screw usually located on the right side. Turn that out about 3 turns. Have someone help you manually lift the engine and while it is up tighten that screw back up and it should stay. From there you can check your trim lines and check the Cylinder for leaks. Also check to make sure that there is no water in the system. Once the engine is all the way up just engage the tilt lock and you will be able to do anything that you need to without fear of the engine bleeding back down.
May 23, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP Logo
65 people viewed this question
Top Seloc Boating Experts
Bill Boyd
Steve P
Steve P
Are you a Seloc Boating Expert? Answer questions, earn points and help others
