Question about Bose SoundLink Wireless Music System 3189731100 Speaker System
Bose wireless speakers cut out
Bose wireless speaker keeps cutting out when using Pandora on my cell phone
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
SOURCE: Bose 901 and Tube amp
The tube main amp will work with series vi 901 equalizer and speaker but the main amp Valves will blow up easily as I have done
Posted on Jan 25, 2009
SOURCE: Replacement speaker (upper) for Bose double Cube.
try a music specialty store or radio shack if you want to only replace the small speakers inside the cubes. If you want to replace the whole cube, there are others out there. Look on ebay and or amazon I think the brand is JA Audio. A knock off of the bose cubes that can be used as stand alone speakers without the module.
Posted on Mar 16, 2009
  • 6 Answers
SOURCE: hook up brookstone wireless outdoor speaker
You cannot add other brand speakers to Bose systems. You must purchase the Bose second zone speaker amp and speakers.
Posted on Apr 27, 2009
SOURCE: Bose Ipod docking station not working!
Make sure the power supply is connected properly. If the power supply is connected upside down or sideways, the system will make a thumping noise, or will not play at all. However, no damage will be caused by connecting this wire incorrectly.
Posted on May 03, 2009
Bose Soundlink Mini paired to Win 7 PC but will not play audio
For pairing your bluetooth Bose speaker to your computer you might need to update the Bose speaker software
I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord.
SoundLink Wireless Mobile speaker update
Aug 24, 2014 | Bose Corp Bose SoundLink Mini
Can't connect my mac and sound link
I'd try going into your Macs Bluetooth preferences, delete the Bose from its memory, then start a new search for devices.
Apr 08, 2014 | Bose Soundlink Wireless Mobile Bluetooth...
Pandora on iphone keeps stopping and starting every few seconds
I've only ever experienced this problem due to a slow data connection. You might also try restarting your device (cutting it off and cutting it back on). If you have a lot of applications running, it might keep it from getting enough of the system resources.
Nov 15, 2012 | Apple iPhone 4S
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Sound keeps cutting out. Have to reboot to get back. Please help
you can try uninstalling and reinstalling the drivers,or also try to update it
Jun 14, 2010 | Bose Companion 5 Multimedia Speaker System...
Have a pioneer VSX-D603S and just added bose 100 watt speakers. As i turn up the volume the speakers keep cutting out. Not very loud before it cuts out. What can I do?
What model of Bose, how connected on what channels? Do you know the impedance? If they came from one of their all-in-one systems you're playing with fire (almost literally) mixing them with non-Bose amplifiers.
Feb 04, 2010 | Pioneer VSX-D903S Receiver
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
Lifestyle 30. sound stops, i unplug and plug back in and works for short time and quits. unpllug and plug back and works a short time and quits.
What you describe, sounds like a speaker short. Are you using the Bose wiring with their ends and no cuts in the wire? (splices) It's not too uncommon to extend or shorten a wire. The fastest way to find a short is to disconnect your speakers at the speaker. Be careful to keep the wires separate if they are not on plugs and turn on. If it cuts off (power) or says (protection) on the display that lets you know your speakers are ok and you have a short in the system or a wire. Next, disconnect wires at the sub one by one and test until it causes the system to cut off or short. Leave that speaker disconnected from the sub and test with all others connected. Now you've located the channel that has the problem. First just connect the wire again to the sub. if it cuts out, run a new wire from the sub to the spkr, for testing purposes make it a short wire if possible and test. If you need to use a Bose plug at the sub to test spkrs go buy one at Bose, don't cut your factory wire just yet. If a new plug works then cut and replace. Make sure you use electrical tape not scotch tape or duct tape. If it works fine, test the new plug on the old wire and see if it works. If it does your done, if it doesn't, run a new wire to the speaker with the new plug on it. If after all this and it still doesn't work. Sounds confusing I know, It's just process of elimination, that's how we do it in the field. If all your speakers are disconnected and it still cuts out, it could be the sub or the receiver. Take it to a Bose store and they can check each piece for functionality. If it needs repaired let Bose do it. Hope this helps.
May 10, 2009 | Bose Lifestyle 28 System
Bose SoundLink Wireless Music System 3189731100 Speaker System Logo
101 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
