Question about Sharp R-520KS Microwave Oven
Won't cook timer counts down fan turntable work when door is opened
Replaced bottum door switch
SOURCE: sharp R930AW oven doesn't work
IF, you experience a problem similar to the one in which one or more of these switches can cause, always suspect first an item or component that is mechanical. In other words, the parts that have moving parts usually provide symptoms that appear to be very complex in nature, but are simple in what it may take to remedy or fix. For instance, if the convection portion of an oven as the R-930AK does not work or is intermittent, look to these referenced switches. I've even had the unit work when tilted at some degree of angle and stop working when moved beyond that angle. This was caused by an old switch. Actually, the fatigue and dirt with age, had caused the little pink actuator to only work when at an angle beyond that of horizontal which then did not require as much tension to allow to go shut. It was almost like a mercury switch on a thermostat or a pendulum anti-tilt switch on a pinball machine. Remember, what can wear out, probably will.
Posted on Oct 25, 2007
  • 619 Answers
SOURCE: Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Posted on Jan 03, 2008
tiway1
  • 100 Answers
SOURCE: dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Posted on Dec 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-530ES microwave oven stopped working
You have a bad secondary interlock (lower door switch) or its mount is damaged or out of alignment.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidare microwave fmv156dcf:Timer and light work but no heat,
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (wiring diagram) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Posted on Jan 03, 2009
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
Frigidaire model cfmv156fmc allows programming, lights work but when hitting go wont turn on yet timer is counting down.
If the inside light comes on when you try to cook, but the turntable and internal cooling fan do NOT, then that's a bad bottom door switch or that switch's mount.
See this helpful text file.
If the inside light, turntable, and internal cooling fan DO all come on when you try to cook, but it does not cook, then you have a bad relay or connection on the control circuit board, which we can repair for $39.95. Details here.
We have the service manual and have uploaded it to our site here to help you.
Jan 11, 2011 | Frigidaire Microwave Microwave Oven
Set control board to cook and not working
you have a bad door switch, check for burns on the switches and connectors, if not its the pc board
Jan 09, 2009 | GE JVM1631 Microwave Oven
My FMV156CC
if you take your control pael off and look inside where the door closes there should be a setup with 3 switches the middle is the monitor switch and it is bad needs to be replaced.
Nov 27, 2008 | Frigidaire FMV156EM Microwave Oven
Panisonic oven NN9854P
I suspect a door switch or mount.
Usually a unit with a bad door switch or switch mount will still count down when you press Start, but will not heat.
The fan, turntable, and inside light may or not run, depending on how the unit is made.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Microwave Ovens
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Frigidaire won't run
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
Timer will run, but won't cook
Sharp R-520KS Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
