Question about Haier C-RNU1708B 1.7 Cubic Feet Nucool Compact Fridge - CFC Free - Ste
Nucool mini fridge
Isn't cooling
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I have a nucool mini refrigerator 2.8 cu. ft. I
Dear Friend!
Without knowing exact fault, replacing modules will not solve the problem. Check compressor is working, If so, keep your arm on condenser coil or discharge line. If you feel hot, it's working If not no gas. If working, you will get slight whistling sound on initial stage in freezer, as gas flows. If no soul\nd like this, gas chocked. You have replace filter drier and flush out system and recharge gas. My humble advise to call repairman to check completely. Thanks.
Posted on Feb 02, 2011
My frigidaire mini fridge won't cool. Ice builds up on one of the wires on back and the cooling unit (I think) gets very hot
It sounds like it could be a restricted Capillary tube, which would require a sealed system repair by a professional repair person. A new mini fridge might be the way to go.
Sep 20, 2014 | Refrigerators
Mini fridge wont get cold
How old is it? You proablaly need REFRIGERANT!!!
Jul 21, 2012 | Haier C-RNU1708B 1.7 Cu. Ft. NuCool...
Ive just bought a hot point ffa74 fridge freezer an it's now been plugged in for around 3/4 hours and the freezer isn't getting cool neither is the fridge, on the control panel there is a green...
The normal cool time for a machine is up to 24 hours, so I wouldn;t worry about anything at the moment, but if the product isn'l cool by the morning I would return it as a defect
May 14, 2012 | Hotpoint Refrigerators
My chef mate mini fridge isn't cold
buy a new one cheaper than repair
Apr 30, 2012 | Refrigerators
Maytag MDS2351- came home one day and noticed water coming from where u get the ice and water when i opened the freezer it was not cool and everything i had in there was defrosted and then when i went to...
Your fridge operates like that: a compressor liquefies freon vapours; this creates heat so the hot liquid goes thru a cooling radiator with a fan on it (these 2 elements are at the rear bottom of the fridge) the freon fluid goes to an evaporator, turns to vapour and absorbs heat in the process, cooling the evaporator; a fan blows air over the evaporator and spreads the cooled air all over the fridge; the vapours return to the compressor.
In the rear of the fridge you should make sure that the radiator is clean and the fan working; inside the fridge you should make sure that the evaporator is not covered in ice and/or dirt and its fan is working. If necessary clean both.
If they are clean , the fans work but the evaporator isn't cold then either the freon circuit has sprung a leak and all the fluid has been lost or the compressor isn't working - to find out which just put your hands on the compressor : if it's hot and vibrates the fluid has been lost, if it doesn't vibrates then the compressor isn't working.
The compressor isn't working because either the thermostat or itself have failed. To find out which the compressor will have to be powered directly from the mains: if it starts then the thermostat must be replaced, if it doesn't the compressor will.
To fix the freon circuit or to replace the compressor a certified professional is mandatory, you must call one.
Jul 12, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
I have an older Whirpool fridge it isn t cooling
does the motor run if not change the thermostat but if it runs the gas level are low in the system
Jun 16, 2009 | Refrigerators
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Haier C-RNU1708B 1.7 Cubic Feet Nucool Compact Fridge - CFC Free - Ste Logo
449 people viewed this question
Top Haier Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Haier Garden Expert? Answer questions, earn points and help others
