Question about Sony Televison & Video
Problem sony tv kv2197 go on standby.when power on a few sec tv on and go to standby mode. pls help me
  • 448 Answers
You may try resetting the TV to the original factory settings. If the issue persists then service will be required.
Posted on Jun 27, 2009
I think it is tube problem
Posted on Sep 04, 2009
Sony lcd brava having problem that it goes in standby mode after 2 sec automatically what can be problem pls help me
When you attempt to turn on the set, the standby light should end up blinking a number of times, pause then repeat the blinking. Please count the number of blinks and post here along with the model number of the set. With that information we will be able to guide you to a solution.
Aug 31, 2016 | Sony Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Tv stuck in standby mode
When a TV is stuck in standby mode often means that there is a problem with its power supply or even in the horizontal output circuitry. May be a component with short-circuit in the RGB output driven by the flyback transformer or a rectifier diode in the power supply output.
I hope having helped you.
Sully
Sep 27, 2013 | Sony Televison & Video
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
Relay clicks, but No sound, No picture.
Hello, just try this first.
Unplugged the unit the power outlet for about 60 sec.Then power it on again. If you have surge strip along the line. You should directly switch in on power outlet only. If this doesn't help.
As the relay is working you have power in standby mode. Check its supply voltages if its ok. Secondly you can check the the B+ supply it is in DC, If this is a crt type tv, check its horizontal output transistor, Check its flyback for short circuit. Capacitor near to it rated almost 800V, and deflection coil.
Just for input, hope it helps
Apr 19, 2009 | Daewoo Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Televison & Video Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
