Question about LG Washing Machines
My washing machine is presenting LE error, I have already replaced part # 6501KW2002A - Hall Sensor Assembly. I try running QC test, I have cleaned filters on back of machine, I have drained off the water in the little hose in front-botton part of machine....But, problem percist..... I have even tryed pushing Spin-Soil togetter and then Start... What can I do now ?
LE = locked rotor. Replacing most common problem (hall effect sensor) didn't work.
1. Is rotor really locked?
2. Does control board simply think rotor is locked?
3. Is wiring good?
4. Did you install a defective sensor?
5. Is circuitry on control board bad, and reading sensor wrong?
6. Do you know any good repair people who are good with high tech? I do. . . ME!
Good luck.
Posted on Jun 01, 2010
WM3875HWCA will not spin gives error code LE
Most likely caused by the Rotor Position Sensor (aka Hall motor sensor) going out or intermittently working.
LG Part Number: AP4440680 cost is about $27
See this video for more information on replacing it, it's similar:
Washer Rotor Position Sensor Switch (part #6501KW2002A) - How To Replace
Nov 28, 2017 | Washing Machines
My lg front load washer WM2016CW wont spin on spin cycle
LE is caused by one of two things
1. Using regular detergent, not HE detergent, oversudsing confuses sensors and you get the code or
2. (Most likely- the position sensor also known as the HALL sensor is bad and needs to be replaced. Easy fix. Part under $20.
http://www.ebay.com/itm/LG-Electronics-Washing-Machine-Rotor-Position-Sensor-Assembly-6501KW2002A-NEW-/262272820807?hash=item3d10ada647:g:az0AAOSwnLdWsMSa
check out out YouTube or repairclinic.com or appliancepartspros.com for videos.
Jan 26, 2017 | LG Washing Machines
LE error (checked stator and replaced HAll sensor already)
If the control board does not receive the input it will not operate does the door lock? However:
The attachment shows how to diagnose and repair a failed hall sensor, the usual cause of
an LE error code.
DO NOT replace the stator until the hall sensor has been tested. 98% of LE error codes are
caused by failed hall sensors.
[DD motor SVC check process ]
Pre Check
1) Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the
drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
2) Don't replace the PCB when the hall sensor is replaced.
Check the hall sensor as shown in the new process.
O have a file I can send but can not upload here if you want it, contact me melissamaemartin@yahoo.com please put hall sensor in subject line. Thanks
Mar 28, 2014 | LG WM-2277HW Front Load Washer
Some cycles work but not consistently so oe error occurs repeatedly and le occurs every day for last year with the door. But now can't do wash so have done everything from checking all fitlers, clogs,...
That would be the first part to replace. The hall sensor is located in the motor and it's not too difficult to replace. You will need a 17mm socket to remove the center bolt holding the rotor and a 10mm socket to remove the 6 bolts holding the stator assembly. Good luck.
Jun 17, 2011 | LG Washing Machines
MY LG WASHER MACHINE IS NOT SPINNING AND CODE IS COMING UP LE
The LE error is a Locked Motor Error.
Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly.
Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable.
Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit)
Or the hall sensor is out of order/defective.
Or the Actual main motor is defective.
Nov 08, 2009 | LG Washing Machines
Replaced sensor on motor and ran find empty put cloths in washer runs for a bit then le code comes up help
LE means a locked motor error. sounds like you already replaced the hall sensor so the next thing to look at is the Stator Assembly it may have an open circuit.
Nov 07, 2009 | LG WM-2277HW Front Load Washer
My LG washing machine will not run through washing cycle
Locked motor error (LE)
* The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
* The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
* The hall sensor is out of order/defective.
***. If the hall sensor is defective, replace the entire motor.
Jul 13, 2009 | LG WM1814CW Front Load Washer
LG Front load washer LE error code
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
You can order parts by your location by CLICKING HERE
Nov 21, 2008 | LG WM-1832C Front Load Washer
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
188 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
