Question about Sharp LC-32LB150U 32" LED TV 1920x1080, 60 Hz, HDTV
Turn off messages - Sharp LC-32LB150U 32" LED TV 1920x1080, 60 Hz, HDTV
I dont want to see the little preview of text messages that turn up on our home screen when a new text (SMS) message comes in.how To turn this off in samsung grand 19082
Most of the time if you open up your messages and open the Message settings there will be an option to Turn Off Message Notifcation Preview or an option that says "Display only Phone number", "Display text message", etc. Just select the one you want.
Nov 30, 2013 | Samsung i9082 Galaxy Grand Duos Dual SIM...
Get card locked message when I turn camera on. Can't turn the message off,\.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 14, 2012 | Samsung SL35 Digital Camera
Message light will not turn off even if there is no msg
Not true. The message light WILL turn off when there are no messages. The messages don't have to all come from the voice mail system.
Press MESSAGE and look at the display. It will tell you where the message came from and you can either CALL or CLEAR the message, using the soft keys. When you clear all messages, the light goes out.
Carl
Nov 14, 2010 | Panasonic KX-T7630 Corded Phone
How do I reset the oil life indicator on 2006 Saab 9-3
Switch ignition ON. Press brake pedal. Press button [A]. RHD - 100248. LHD - 100254. Turn button [B], until the message "System Settings" is displayed. Press button [B]. Turn button [B] until the message "Service Info" is displayed. Press button [B]. The message "% left of oil quality/days to service" is displayed. Turn button [B] until the message "Reset Service Ind." is displayed. Press button [B]. The message "Are you sure? Yes or No" is displayed. Turn button [B] to select "Yes". Press button [B]. The message "service parameters updated" is displayed. Switch ignition OFF.
BUTTON B IS ROUND PUSH/TURN BUTTON
BUTTON A IS TWO DOWN FROM THIS
May 08, 2010 | 2001 Saab 9-3
How do I turn on the message waiting light option?
The adminstrative option of Centrex IVMX allowed me to turn the notification message light option "ON".
Aug 04, 2009 | Meridian Lands Phones
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Lost manual for phone KX-TCD420ES , cannot retrieve messages
Press INT (Bottom right black button) then # then follow instructions. Press 4 for new messages and 5 for all messages.
To turn answer machine on and off – press INT, #, 0 to turn it off and INT, #,8 to turn it on.
My question is how to change answer machine message, any ideas?
Jan 01, 2009 | Panasonic Lands Phones
Picking up messages remotely
Try this...
Remote Operation
Command Function
Dec 12, 2008 | GE 25942GE2 Cordless Phone System
Sony cybershot DSC W50
when I turn the power on screen is blue with "access" message. after a few minutes, message is replaced with "turn power on and off". I have removed and recharged battery but keep getting the same message and other functions of the camera will not work.
Apr 30, 2008 | Sony Cybershot S650 Digital Camera
Message waiting light won't turn off
Have u ckecked whether the message box is full?
Try clearing all the messages from the setup menu
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Feb 06, 2008 | NEC 80573 Corded Phone
Sharp LC-32LB150U 32" LED TV 1920x1080, 60 Hz, HDTV Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
