Question about Black & Decker V9650 DustBuster Handheld Wet/Dry Vacuum
Opening a hoover help-mate
Need a diagram to show how to open it
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Lid of filter section stucked in Hoover Vaccum Cleaner Model UH70115
Hi Bharat! In the front of the dirt cup near the top there is a red Hoover emblem that is also a latch to open the dirt cup lid. Pull on dirt cup latch to open lid. Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
Dc 54 how to open bin
Hi there, it's Jack at Dyson.
Once you've removed the clear bin and cyclone from the main body of the vacuum, the red button on the cyclone top will open the bin base. This diagram should help:
Our Getting started video guide also shows how to remove and empty the bin after use:
I hope this helps, but if you'd like any further advice you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 24, 2014 | Dyson Vacuums
Why is the red bar still showing when I've cleaned both filters?
If you hear the motor running you have to have an air leak. Check all areas where parts mate together or anyplace where there is a gasket on the mating surfaces.
Aug 10, 2014 | Hoover Vacuums
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
http://hoover.com/file/597/
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/index/?manufacturer=37&q=floor+mate
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
I NEED TO SEE WHERE THE DYSON 15 SPRING TO PUT IT BACK INSIDE THE DYSON.
If the spring is from the cleaner head assembly, this webpage will show you where the spring goes.
If it is not from the cleaner head, then click on one of the links to the left under "narrow by category" and that sections diagram will open up for you. Good luck!
Hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Apr 11, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Black & Decker V9650 DustBuster Handheld Wet/Dry Vacuum Logo
77 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
