Windows 7 - issue seen Ubuntu - the same issue Linux Manjaro - same issue BIOS Version F.19 07/06/2010
SOURCE: How to replace the Keyboard?
i have a hp 6910p laptop and need to know what screws to remove.
SOURCE: notebook heating problem(urgent help)
You bios versions start at f.03,f.04,f.05, f.07, f.08,,,
The date and version that you posted does not match and bios version for your model.
The only reason you update a bios is if it falls under the problems
listed for the new bios to correct.
Say your lap came with f.05, the only reason you would update to f.07 is because you had a graphic error,that the new update fixed.
The link below is the page for your drivers, if you look at bios,it shows the newest,if you click on version,you will see all the ones
that where made.
You should double check to make sure that you have the right bios version.
http://h10025.www1.hp.com/ewfrf/wc/previousVersions?softwareitem=ob-61399-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3646603
SOURCE: Audio drivers for HP compaq nx7010 with Windows 7
This WEB site can supply the Windows 7 drivers, please click on this link :-
http://www.user-guides.co.uk/cddownload/HP/HPCompaq/HP-Compaq-nx7010-Windows-7-Driver-Recovery-CD-Restore-Disk-313489.html
SOURCE: Hp compaq 6910p BIOS Bypass
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
SOURCE: I have a laptop hp Compaq 6910p, and by mistake I ...
Its too risky for a user to open the laptop, access the mainboard and reset to its factory setting..
Very dangerous for the hardware too..
My suggestion is to bring your laptop to a credible technician to open your laptop, reset the cmos to its factory, and return the cover properly..
Hope you understand.
Much appreciated if you rate this help.. thanks
