Question about Sub-Zero 690 Side by Side Refrigerator
Light doesn't always go on in refrigerator sub zero 690
  • 56 Answers
SOURCE: Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Posted on Dec 03, 2008
SOURCE: sub zero 690 the control lpanal light does not come on
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free.
Good luck and I hope this help.
Byron12020
Posted on Dec 17, 2008
  • 31 Answers
SOURCE: Need to change the water filter on my Sub Zero
Hello. The factory indicates your unit required an in-line water filter if your plans were to use one, or the installers added it. There was no indication of an internal filter in the fridge itself. If there was it should be easy to see or find. However this can be good news for you also as your filter (if installed) migt be easy to find and access behind or near the fridge if installed well and a good quality but common form of water filter you can easily replace may have been used, if installed. Otherwise if you have whole-house water filtering already they may not have added any further filtering.
If you can contact who installed your 690 they should be able to tell you where they installed it and what type. If not just have someone follow your water line to the fridge unit, and see what turns up as you make your way along to the place where water connects to the fridge.
http://www.subzero.com/resources/products/downloads/600installguide.pdf
Posted on Oct 23, 2009
  • 7 Answers
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Posted on Dec 11, 2009
SOURCE: sub zero ref 690 s model with error code ec 50
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
Posted on Jun 23, 2010
How do you install or change the water filter.
If you model Sub Zero 690 has a filtration system this is what to look for. Thanks John Tripp Appliance 911
Contact Me Here
Sub Zero 690 Service Manual
Sub Zero Installation User Manual
CONTACT INFORMATION Sub-Zero Customer Service:
800-222-7820
Website: subzero.com
E-mail Address: customerservice@subzero.com
Jul 07, 2014 | Sub-Zero 690 Side by Side Refrigerator
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub zero ref 690 s model with error code ec 50 what is that
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Light on refirgerator side doesn't come on unless I tap switch.
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Sep 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
How do you reset the fridge to remove the vacuum condensor light on our subzero 690 refrigerator
You have to press the unit off button inside of the refrigerator and then press it again to turn the fridge back on. The light should go away after that
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
8 year old Sub-Zero model 690. Condensor coil leaking
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Sub zero 690 the control lpanal light does not come on
Byron12020
Jul 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
23 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
