Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Wheres the drain plug located on 2166 cub cadet tractor
  • charles beach
    charles beach Dec 17, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 97 Answers
SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Posted on Mar 17, 2009
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
Cub Cadet 2166 backfires when it gets hot.
powerwash the whole unit,make sure there is no build up on the head of the motor and all the fins around the motor,make sure that the heat deflector is installed properly,(Cub CadetKH-12-029-04
Adapter, Carburetor), #5,e09ec3f9-dc41-4345-8407-4807ef5e1296.gifalso be sure to clean the spindles and under the mower deck,also make sure the blades are sharp,grease all fittings,if the mower turns freely then there is less effort by the motor, 93d5c4db-8241-4eb5-94d5-cf708bb2f401.gif
here is the parts list for the mower,http://www.partstree.com/parts/?lc=cub_cadet&mn=2166+Tractor ,
May 21, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2166 pto not working
check fuse then check to see if power going to pto if is bad pto if not check switch then safty switches
Apr 18, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
Jun 11, 2012 | Cub Cadet Garden
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
Cub Cadet 2166 tractor, changed transission filter and oil
did you check to see if your belt was in good shape and if the hydro relef was in
Apr 14, 2012 | Cub Cadet Garden
How do you change the battery out of a Cub Cadet 2166 mower?
disconnect the ground wire first then the pos one there should also be a few bolts that hold the battery down
Mar 29, 2012 | Garden
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Jul 10, 2010 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
51 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
