Question about Fleetwood Food Mixers
Timer dial for model BPS 20B - Fleetwood Food Mixers
ANTONIO
you mean it was not working now?
Mar 20, 2008 | Food Mixers
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
Need circuit card for Hobart Mixer Model HL600C
ge is a recitml# and repost, there are 2 p.c.b.for that mixer 1 is a recipe timer for ml#134317,part#916560, the other is a standard timer part#916557, can be bought @ any hobart location, one would assume that the c on the model # stands for corrections. hope this helps, dont forget to vote, monomoy
Sep 21, 2009 | Food Mixers
HL 600 timer board I think
Sorry so late but the reason you need the kit is because the potentiometer (the knob that selects the time) is no longer part of the timer board.You need the pot,and board.I'm a hobart tech,if any other questions let me know.
Jan 05, 2009 | Hobart A200 Stand Mixer
Question about model numbers
Hi, the "T" means it has a timer, not sure the "D", digital maybe? There are a few Hobart guys on here, maaybe they will post, or you can call your local restaurant equipment dealer, thay should be able to help you.
Dec 31, 2008 | Hobart Food Mixers
Sunbeam Mixmaster model 9 speed control problem
Try www.davesrepair.com/pdfmanuals
You can download the manual for your specific model there, and most of them that I saw included at least basic maintenance like oiling and greasing locations. Good luck!
Oct 26, 2008 | Sunbeam 2386 MixMaster Series Stand Mixer
I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Aug 07, 2008 | Hobart N50 Stand Mixer
Food Mixers Logo
22 people viewed this question
Top Fleetwood Food Mixers Experts
eyecam
Are you a Fleetwood Food Mixer Expert? Answer questions, earn points and help others
