Question about Abit AW9D-MAX Motherboard
The same prob
After removing and cleaning the processor, all i get is 7F and a blank screen
  • 334 Answers
Hey there, first of all, just want to make sure you cleaned and reapplied thermal paste after removing heat sinks (arctic silver 5 the best). Next, do a deep CMOS clear (shorting out the pins on your mobo) followed by booting 4-5 times continuously while holding the INSERT key. This ought to get you back into your BIOS. Good luck, let me know if you need more help.
seth
Posted on Jun 19, 2009
How to raise the top
common prob. with early xk is the hood fluid turning to jelly, the answer is to clean out the system. ie pipework, resovoir etc. to open the hood, open the valve on the pump, located in boot rh, remove blanking plug in headlining. use allen key to release forward hood latch,the hood can then be worked manually.to change the fluid you have to remove the forward hood latch. disconnect pipes, press the hood switch to pump out the old fluid,remove the pump and drain out the old fluid, work the hood manually 3 or 4 times to extract the remaining old fluid, the correct fluid to put back is pentosill it will bleed itself.if this is not the cause of the prob. then its electrical. go to a auto electrician you will need a wiring diagram of the system to sort that out, its got loads of relays e.t.c. and is controlled through the body processor module.
Mar 17, 2014 | 1997 Jaguar XK8
My laptop is Compac presario CQ40. it's screen goes blank i can hear the voice which is running but screen goes blank and i have to shutdown and start afterward but the problem persist. My laptop work...
1. Faulty RAM - try to remove, clean, re-align.
2. Remove battery, press power button for at least 30 secs. w/o AC power. Attach to AC power without
battery. power on. Hard reset
3. Faulty Processor - very risky of dismantling and aligning processor.
4. MOBO problem.
Mar 15, 2011 | Computers & Internet
Hello all: Still have this problem. Anyone out there able to fix this problem? Sony VGN-NW160J 4 gig ram 340 gig HD Screen will not come on. Will not boot, cooling fan spins, and hard drives hums and...
remove the computer covers remove the memory from slot and clean the memory with clean soft clothalso remove the processor fan from the socket clean the surcace of the heatsink and the processor and apply thin layer of heatsink solventand fix the processor fan firmly on the processor socket
Jan 15, 2011 | Sony Computers & Internet
Power on screen blank.. fan on
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. You can disassemble or remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion dv6704nr Notebook
Blank screen
Double check the processor. Sounds like the processor is not inserted correctly, or it is not locked in by the socket lock.
Oct 25, 2009 | Computers & Internet
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
When i power on,screen is blank, memory n processor are good too.
You need to check your RAM, if in case, remove it, then you need to clean the terminals (the gold ones found in the bottom, then clean it with a pencil eraser, then put it back. do not use any cleaning liquids as this may destroy the RAM
Feb 27, 2009 | HP Pavilion dv2500t Notebook
Model #3522GZ gateway lap top
try right clicking c:\ tools scandisk fix problems reboot see what happens tried this on a lot of computers solved alot to
Jul 09, 2008 | Computers & Internet
Abit AW9D-MAX Motherboard Logo
113 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
