Question about Brother Office Equipment & Supplies
Brother PT 80 won't turn on - Brother Office Equipment & Supplies
P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Jan 20, 2013 | Brother BRTPT65 PT-65 Label Maker Printer
Have inserted new batteries and new cartridge but not able to print
Sounds silly, but are the batteries good and are they correctly installed. Check the pictogram in the battery case and make sure that the batteries polarity complies. Also check that the cartridge is securely fitted and the tape feed is correct.
Jan 17, 2011 | Brother P-touch PT-80 Label Printer
I have a few keys that are not working
call the company about the warranty first, if none then ask where you get it repaired
Oct 21, 2010 | Brother P-touch PT-80 Label Printer
I have lost my direction for my PT 80 Label
hi!
here's the user manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_1180_EN_132.PDF
hop this helps.
Sep 23, 2009 | Brother P-Touch 1180 Label Printer
MANUAL FOR P-TOUCH 80
Dear Sir,
I feel Happy to assist you.
Manual For P-Touch you can download below Download Link.I think it solves u r problem.
Download
Jul 10, 2009 | Brother P-touch PT-80 Label Printer
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
