Question about Krups 574 Power Xtreme VI Premium Work Top Blender
O RING 574 - Krups 574 Power Xtreme VI Premium Work Top Blender
  • Krups Master
  • 1,248 Answers
There are 4 Krups 574 models, the seal shows as obsolete for 2x of them and still current for the other 2x
Part number for the seal that is current is MS 0974091
Posted on Oct 31, 2015
Part number and price
You have to contact the manufacturer for that kind of information. We do not have part numbers or prices. We do not sell any parts.
Feb 23, 2014 | Krups 574 Power Xtreme VI Premium Work Top...
My cousinart blender is leaking. It appears that the locking ring may have been screwed in a bit crooked as the rubber washer is not sitting flush and tight. My problem is that the locking ring is so...
sounds like the locking ring is cross threaded. It will be difficult to unscrew, but the only solution is to remove it and put it back on strait. soaking it in hot water may help if there is a dried liquid acting as an adhesive.
Sep 27, 2013 | Blenders
The small rubber? ring on the bottom of the immersible bleder is black, and it smell burnt. What can I do? Is there a replacement part? What is the address(e-mail) for replacement parts? Thanks,...
First identify if it might just be an "O-Ring". Some of these can be found at auto parts stores or local hardware stores. Also check for O ring suppliers in your local phone book. Lastly, find an appliance part store near you.
Nov 06, 2010 | Wolfgang Puck Immersion Blender
When I use the blender it is difficult to get it tight enough on the bottom so that the liquid does not pour out from the bottom. The ring is not cracked. I have had this problem for a long time and it...
Try tightening the ring by (unplugged), align and tighten the base ring, rubber touching glass, then the blade plate assembly, then the ring....Then place on the machine, press down and tighten more...
I find that you cannot sometimes get enough tighening by hand, due to the dimention of the ring and the human hand...
Oct 27, 2010 | Back to Basics Smoothie Elite Work Top...
My toilet is sliding - I have been told that I need a new toilet seat because the screws are not having any effect when tightened. I don't want to take the screws out because the remainder of the...
The screws tthat hold the toilet to the floor rin\g are twisted into a slot in the ring. If yopu go to a building supply store you can look at the ring and anchor bolts and see what I mean, the heads of the bolts are oval and dfrtop thru thr oval holes in the ring , then a 1/4 turn and tighten .. to remove just loosen, turn the bolts and pull them up out of the floor ring. they may pull hard because of the bees wax .. but they will come when they are lined up with the oval holes.
Oct 20, 2009 | Back to Basics Smoothie Elite Work Top...
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
I have i blend 5 speed and i turn it on and nothing happens
COMMON sorry to say , the problem is with the control , there is no fix except to return it . what i have been telling people is untill appliaces start getting better and not just this PRETTY JUNK from china go find a goodwill store and get a nice 20 year old blender and you will have it for years . or if you have the bucks buy a VITA-MIX there good but expensive good luck
Jan 15, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
Open Questions:
Krups 574 Power Xtreme VI Premium Work Top Blender Logo
161 people viewed this question
Top Krups Blenders Experts
pdavis1000
Level 1 Expert
Kolbrun...
Ross Keen
Are you a Krups Blender Expert? Answer questions, earn points and help others
