Question about HP OfficeJet 6210 All-In-One InkJet Printer
Do I put the original print up or down - HP OfficeJet 6210 All-In-One InkJet Printer
  • 400 Answers
If you want to print on both sides then put the print up .
Posted on Jun 19, 2009
Put new cartridegs but not printing
If you put new cartridge original canon and not printing nothing,you need to replace the print head,the print head is under the cartridge.If i have been useful pls give me a vote :).Thanks
Mar 28, 2011 | Canon PIXMA iP90 Mobile Printer
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
Whitch way does the paper go in for faxing ?
If your using the feeder on the top of the scanner, it should go face up. If you are faxing from the glass - face down.
Oct 29, 2009 | HP Officejet 6500 Wireless All-in-One...
Trying to cancel a print job on Lexmark X1270
I tried all the recommended solutions I found on FixYa but none seemed to work immediately. I decided to disconnect the printer from the PC for an hour or so and this did the trick. Not sure if that solved the problem, or the simply that the printer was working very slowly to delete the original printing request. However, I now know where to seek help in the future. Thanks anyway
Mar 30, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Testing print cartridge
Printing is not possible with B-820. You can just make a copy of an original print. Put the original in the mentioned place, it displays 'Document Ready' then just press 'START' button twice. you'll get a copy.
Aug 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
My all in one wont copy/scan, but will print
If you arnt putting the original upside down then it will need scanner replaced, no easy fix... approx $Aus250.
Dec 13, 2007 | Brother MFC 9700 All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
