Question about Exercise & Fitness
I have a nordic row TBX. It's old not sure of model, but the cord does not retract. I think the spring has broke. Where do I get a replacement ?
Thunder55
  • 318 Answers
SOURCE: cord will not retract
If you are not a vacuum repair technician, dont bother,,because this is not an easy repair to make
Posted on Jan 16, 2009
bobbyburns
SOURCE: Reattaching the recoil spring to the rope pulley
i have the same probelm
Posted on Jul 08, 2009
  • 32 Answers
SOURCE: Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
Posted on Jul 23, 2009
SOURCE: trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
Posted on Jul 04, 2010
davieandvera
  • 12 Answers
SOURCE: Pull cord broke on my lawn boy mower,new cord won't retract??
Well done on replacement of cord...but it appears you have not PRE TENTIONED the cord by holding the cord and turning in the same direction as pulling untill some resistance is felt (to pull the cord back in) then it must be held while you thread it through the out let and pull handle and make a big knot! Test to ensure pawls come out to engage with pulley...fit same job done!! Cheers
Posted on May 08, 2016
How do I fix the pull string on a push mower?
Hi Barbara:
The pull start assembly is usually attached by 3 or 4 bolts.
Start by removing it. Depending on where the pull cord broke, you may be able to use it shortened a bit, but replacement is probably a good idea.
There is a spring inside the thing the cord winds around (spool)that retracts it after you've pulled on it. The tricky part is making sure that the spring is wound up enough after you've installed the replacement cord.
Look at the way the old cord is installed. If you can, grab it with some pointy pliers and pull it all the way out, winding up the spring tension at the same time. There should be a way to hold the spool (look for a hole you can slip the end of a nail into) so you can change the cord. Then Take the nail out and make sure the cord retracts all the way.
Next step is to re-install it on the mower.
Cheerfuls!
Jun 13, 2015 | Garden
The rope does not retract when the cord is pulle... how do I fix it
Has the cord been replaced? If so, when the old one broke, the spring will completely unwind. The trick is to rewind the spring first, attach the new cord and wind it around the spool while holding the spring tension. After the cord is wound, feed the end out through the cord port and test for good return (don't let go!!), then clamp the cord with locking pliers and affix the handle to the cord. Melting the cord ends helps keep the knots from pulling out. Hope this helps!
Jun 07, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
The retractable cord will no longer retract into the vacuum. The vacuum is a month old.
rewind spring broke return to where you bought it for replacment
Feb 10, 2010 | Vacuums
Cord won't retract
The spring is either broken or the catch on the end of it isn't seated, this is a coil spring inside the hub, probaly has to be rewound to gain the tension back
Aug 22, 2009 | Garden
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Cord seems to be slipping off the flywheel; I pull and the cord goes slack, spools out much more than is needed, and when it retracts (basically from my stopping the pull and slowly letting it reel itself...
You have a bungee problem, your bungees broke. You can easily order new bungees from your manufacturer. They are also easy to replace once you take off the side of the fan.
Jul 15, 2009 | Kettler Coach Rowing Machine
How to replace starting cord in Victa motor mower
or the spring has come out the locating thing inside ... put more tension on it and repeat the assembley.
Mar 01, 2009 | Garden
Power cord will not retract
It sounds like the rewinder spring either came off the retainer or broke. If it broke it must be replaced. If it just came off, it can be put back on and rewound. It is a LONG flat piece if springsteel which is VERY sharp. Be Careful.
Dec 17, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
