Question about Whirlpool duet Dryers
Jscott326@hotmail.com dryer starts only but only heats in certain cycles, turns off after 5-10 minutes will only finish cycle uaing no heat
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
SOURCE: Intermittent Heat
For what its worth, I found out what was wrong with the Kenmore Elite 110-62882101. The circuit board works a small relay that works the heating element. We replaced the thermister, then the circuit board - to no avail! Finally, we replaced the relay, and the problem ended. Seems that the relay didn't always make up even though it clicked. It's a Potter Brumfield (and old line company) but made in China (what isn't?). The guy is the local parts store says the motor relay is the same type (they look alike) and that these caused trouble in the past. The heat circuit didn't use relays in the past (when there were thermostats), but they do now (that temperature is controlled by thermisters and circuit boards). So, the lowly, seemingly simple and reliable heat relay can be the problem - if your dryer has one. --- Powerguy
Posted on Mar 04, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
SOURCE: Turning no Heat, clean filter lights on while turning
usually heat element or high and low limit sensors need changing, check vent lines are not plugged or 220 breaker if split breaker is only tripped on one side?
Posted on Jul 25, 2008
MNTECH
  • 1543 Answers
SOURCE: My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Posted on Aug 27, 2009
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 08, 2015 | Whirlpool Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Dryer drum turns, heats, but then heat shuts off before timer has finished.
The heat is supposed to turn off ten to fifteen minutes before the end of the cycle. It's a cool down period.
Jan 08, 2014 | GE Profile DPSB613G Gas Dryer
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Drum is not turning. Heat works
Sounds like the belt has broken or come off. This is usually inexpensive to fix. You just need to get it out in the open to replace.
May 25, 2008 | Asko T761 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
