Question about Plumbing
Grohe kitchen faucet burst supply line
In November 2006, we remodeled our kitchen and had a Grohe Ladylux plus kitchen faucet installed(33737000 model). June 18, 2009 the factory supplied stainless steel supply line burst and flooded the first floor of our home. The break was in the center of the length of the supply, shredding the stainless steel wrapping and exposing a 1 inch split in the enclosed rubber hose. Are you aware of this happening with other customers? Any advice is welcomed.
  • Dory Harris Jun 10, 2012
    This same thing happened to me with a Moen Faucet. Cost me 1,000 and an insurance claim. This should not happen.
  • 297 Answers
With my past experiance with any Grohe product,you will experiance a problem.I have been doing plumbing service work for 20 yrs. and every time I encounter this product,there is always a major problem.I don't know what the big deal is about this product,it cost too much and parts are hard to come by,you must order most of the time.then wait 3 to 4 weeks.hope it's the right part!
Posted on Jul 15, 2009
  • 3 Answers
I had the same problem with my Grohe $350 overpriced faucet. The supply hose split open exposing the thin walled clear plastic tube. I can not even get to the hose connection to the faucet without removing the faucet, the other end is a simple quick disconnect however.
Posted on Dec 16, 2009
  • Zendog Jan 03, 2010
    I was able to replace the 1 year old "bursted" Grohe LadyLux pull-out hose with a generic kit from Home Depot. I used the "DANCO Replacement Universal Pull-Out kitchen Hose" from Home Depot. It had the correct adapters to make it work on the Grohe faucet. It cost only $21 so why speny $58 (Grohe hose replacemt part) when you already know it will fail in one year!! Here is a picture link to the repair kit I purchased:
    http://picasaweb.google.com/lh/photo/WVH...
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How to tighten to sink after install?
the faucet comes with two plastic nuts once you set the faucet into the sink you have the 2 supply male lines use the plastic nuts to attach the faucet to the sink and tighten by hand
Jun 08, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
Aug 05, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Plumbing Logo
877 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
