Question about iLive itb382b 37 hd wireless bluetoothr soundbar
Unwanted volume increases
TV is set to external speaker and TV volume is turned to O. Sound bar is on and turned to modest volume. Within 10 minutes, and periodically thereafter, volume will increase to very loud level. Turn it down with remote, but cycle repeats itself. It occurs during TV show, not just if loud commercial comes on, and also occurs while watching DVD movies and streamed movies. Using optical cable on soundbar and Samsung Smart TV. We live in condo and have downstairs neighbors to not disturb.
2 Suggested Answers
  • 56 Answers
SOURCE: Original and replacement both have same problem of big increase in volume every 10 minutes or so and we have neighbors to worry about. Remote doesn't work quickly in turning volume down, but we need
The source is your issue. The amplifier or TV itself. Try another TV plugged into the amp or some other sound source like a iPod, etc, to test if TV or amp. This is your next step and should show you the proble!m.
Posted on Apr 21, 2014
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
RCA Model 27F520T - it has no sound everything else is perfect?
I'm not sure what options are available in your audio menu, but here are some things to check before having a repairman check:
Click on menu screen, then select audio menu.
If there is choice of external or internal speakers, select internal.
If there is a noise cancelling option, deselect this.
If you are using remote to increase volume, try the manual volume button on tv.
Does the volume bar at the bottom of the tv increase as you adjust volume ?
Hope this helps
May 17, 2011 | RCA TruFlat 27F520T 27" TV
I have picture but no sound. Checked for mute button, increased/decreased volume, unplugged tv and still nothing.
some sets will have an option to turn off the speakers (different from mute); this is used when you want your tv to output to a sound system with external speakers. check your menu settings for something which disables tv speakers--that is probably your issue.
Mar 06, 2011 | Vizio VO320E LCD TV
Re Sony VAIO F12 (new unit): Audio is barely audible using onboard and external speakers, even though volume bar indicates volume is at highest level. Any way to increase audio volume? Thanks.
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
Aug 10, 2010 | Sony VAIO FR130 Notebook
There is no volume on the tv, the volume bar goes all the way to 99 but there is no sound, i plugged in external speakers it worked but the tv volume is not working. How do i fix this problem?
Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
Good luck.
May 21, 2010 | LG 26LG30 26 in. LCD TV
Sound is low how do i turn it up
First of all, if you have volume controls on the keypad, please make sure you turn the volume up from that location.
Next, locate the Speaker icon next to the time in the lower right corner of the screen. Double or single Click on that and make sure the volume slide bar is all the way to the top. If you right click, you may be able to select volume mixer or something similar, there you will find multiple volume settings, turn all up.
Finally, if you are having this problem when using a media player (Windows Media Player, VLC, Quicktime, etc), there will be a separate volume control within the player itself. They are usually a slide bar underneath the video or graphics display. Turn this up also.
Please note that Laptop speakers are notoriously of poorer quality and lack the wattage of desktop speakers. In turn, it may not be a problem with your laptop. You may need to look into purchasing an inexpensive set of external speakers.
Feb 25, 2010 | Dell Inspiron 2200 Notebook
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Increase external speaker volume
when the speaker phone is on, try pushing the up arrow, unless you have the button on the side, But I think it is the up arrow while talking.
Also go into regular menu settings, go to sound settings, speaker volume and headset volumes should both be turned all the way up.
May 30, 2009 | Nokia 2600
Want to increase volume on speakers
You may have already reached the limits if you have adjusted the settings through Control Panel (?). Are these external speakers you are listening through or is it the internal speaker?
In Control Panel (reached from the Start button, bottom left), choose Sounds and Audio Devices. The Volume tab is the first one. Make sure the Device volume slider bar is all the way to the right. Next,choose Advanced and make sure all those slider bars are up to the top with no Mute boxes checked. Finally, at the bottom choose Speaker Volume and make sure those slider bars are all the way to High.
If none of these help and you're using external speakers, it is time to buy a new set. If you only have an internal speaker you're listening with, keep in mind that they aren't powerful enough to give you the kind of volume needed to listen to some things on the web.
Let me know if you have any further questions. Please rate my answer.
Jan 09, 2009 | HP Pavilion dv4000 Notebook
iLive itb382b 37 hd wireless bluetoothr soundbar Logo
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
