Question about Frigidaire FWS445RF
How work how frigidaire washer 9 cycle heavy duty 2 speed
How work frigidaire washer 9 cycle heavy duty 2 speed ?
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
Posted on Jun 11, 2006
caroldon
  • 17130 Answers
SOURCE: frigdaire heavy duty washer 13 cycles 2 speed motor. Washer no longer detects the water level. if you have it on small just continues to fill with water and never stops.. Washer flooded gargage. An
This can be due to failure of the pressure sensor within the washer which should output to the processor to cut off the inlet valve when the set water level has reached.
You can test this out by blowing into the tubing and testing the continuity of the switch to confirm if the diaphragm is intact.
click this link: Replacing sensor
Posted on Jul 05, 2012
richroth
  • 9472 Answers
SOURCE: Frigidaire gallery washer won't change cycles
Look at my other post to you.
Posted on Oct 31, 2012
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Jun 11, 2006 | Frigidaire FWS445RF
Washing Machines Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
