Question about Panasonic KX TG6511 Cordless Phone
Cordless phone not working
Phone says line in use
Will a Gigaset A220 A cordless phone work on a government spectrum phone line
If a telephone line is presented as POTS (Plain Old Telephone System) or a standard telephone will plug into the line, then the Gigaset A220 will work on it.
Feb 09, 2015 | Lands Phones
My cordless phone don't work properly
it is not a Not a stand-alone phone, Each cordless must plug into the 25414 CORDED phone,
Nov 22, 2007 | GE RCA G.E. Thompson 25414RE3 4 line...
Why wont my cordless phone work no reception?
The cordless phones have to be registered to the base station (the part connected to the phone line). Perhaps they are not registered. Check you documentation for information on how to register them.
Jul 27, 2014 | Siemens Gigaset E455 Cordless Phone
Will a panasonic KX-TG2257 cordless phone work with a KX-T6160 system?
I'm not familiar with a KX-T6160 system, so do you mean SIX-SIXTEEN-DEE(616d) or SIX-SIXTEEN-TEN (61610)? Either way, the cordless phone works. You need access codes, like 9 for an outside line, FLASH and dial an extension for transfer, 40 for ringing call pickup (on the 61610), and 58x (61610) to pick a line from hold. Your phone system manual has a single line telephone user guide in it.
Carl
Apr 30, 2011 | Panasonic KX-TG2257 Cordless Phone
Had a bad electrical storm. The next day my cordless AT & T phones ( 1 base with answering machine and 1 remote phone) had no dial tone. They both ring on incoming calls but unable to connect. They...
The damage is not to the phone line it is to the phones. Unfortunately this is very common with powered phones as they are almost never kept on surge protectors and are very fragile. You will need to purchase a new base station to use with existing phones.
Apr 29, 2011 | AT&T 650530003417 Cordless Phone
At&T CL81209 cordless phone. Line In Use light continues to flash. both phones are registered and no phone is in use.
tried the battery unplug thing and it didnt work. read elsewhere on the web that if you have directv then unplug the phone line for it and your cordless phones should work. Tried that and sure enough it did. I dont use directv phone line for anything (i order payperview online for example) but still begs the question how u harmonize using phoneline for directv AND have these cordless phones. They worked fine together for 10 months until last nite.....there was a thunderstorm though. Maybe restarting directv would cure that.
Oct 19, 2010 | AT&T CL81209 1-Line Cordless Phone
Uniden wall-mounted cordless phone unusable since DSL installed
This happened because there are too many phones sharing the same line with no power amplifiers.
Your phone line is self powered by a small current generated by the phone company (that's why old, wired phones don't need a separate power connection to ring or make calls, it's enough to just plug them in). Each phone you connect to the same line acts as a resistor and drains some of this current. Eventually not enough power is left to carry the signal.
The phone company technician can fix this by installing power amplifiers.
In any case, I would test this theory by unhooking all other phones and checking the cordless ones on their own.
If they work fine, call back the phone company and ask for a "real" repair person..
Jul 13, 2010 | Uniden Cordless Phone
I don't get a dial tone when I pick up the phone both the base and the extention both are dead but I have a fax machine also on another line and it works ok
to test the phone system. unplug the phones that are not working from the telephone jack. Install a phone on that phone jack that you know works (an old one or a cheap new phone). If the new phone works on the phone line in question, then your cordless phones are the problem and not the house phone line. If you plug the known working phone into the wall and it now does not work, then you have a problem with the wall outlet or the connection to the house. If it is a phone line or house connection problem, call your phone company. If it is your cordless unit, try them at a different phone outlet or at some other house to see if they work anywhere.
Dec 24, 2009 | Uniden Cordless Phone EXAI985
Can I use Bluetooth headset on Bluetooth enabled land-line phone?
See:http://www.testfreaks.com/blog/review/vtech-ls6245-cordless-phone-with-bluetooth/. Looks like you could at least with this one. I am also looking to do the same.
Dec 12, 2009 | Vtech Lands Phones
No dial tone
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Apr 21, 2009 | Uniden Cordless Phone
Panasonic KX TG6511 Cordless Phone Logo
15 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
