Question about Homelite Workforce 2500 PSI 23 GPM Axial Cam Pump Pressure Washer WF80710
How do I attach soap hose to homelite pressure washer?
Soap attachment
if the bottle is external ,attach hose supplied to bottle and pump. soap will only work when low (big hole)nozzle is used.
Apr 18, 2014 | Garden
Soap feed
I fixed mine works good too, watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
Jan 26, 2013 | Karcher G2650HHR Gas Pressure Washer
HI. My Comet FWS 4030 works just great and i am very pleased. what i DON'T know is how to draw up soap to mix with the water. there is a big red knob, and another brass adjustment but i have no manual...
The red knob is to regulate the pressure. The soap siphon should be hooked up to the pump at the high pressure outlet and the pressure hose hooks up to it. You do just have to drop the tube into your soap solution but I recommend you dilute the soap down as the siphon usually sucks the solution up fairly fast. The trick to making it work is to use the low pressure, soap tip on your wand. They are black and help fan the water/soap out but give no resistance to the water coming out. If you are using a high pressure tip, usually red, yellow, white or green, there will be too much back pressure in the hose and siphon attachment for it to **** up any solution.
May 18, 2011 | Comet GXD2527G Pressure Washer Pump
WIULL NOT PICK UP SOAP FROM CONTAINER
There could be a block in the syphon hose going from the soap reservior to the sprayer. Take the hose off and blow through it to make sure the the hose is clear. If the hose has a scrren/filter on it make sur that is clean also. Where the hose attaches to the sprayer make sure the orifice is clean and not plugger up with scum or other debri.
Mar 12, 2011 | Craftsman 3000 PSI 27 GPM Briggs ...
Do you put the clear hose in the bucket with the cleaner to get it to come out of the spray nozzel? If you dont use the low pressure attachment will the cleaner still come out or not? I cannot find an...
You must use the lowest pressure nozzle with the clear hose in the solution or you will not get soap. Make sure you use only the solutions approved for your pressure washer!.
Jul 02, 2010 | Briggs & Stratton Pressure Washer...
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
My soap will not come out of the hose. What do i
several things to check, soap only works with low pressure tip installed, are you using correct tip? second issue is on bottom of soap tanks some have a small valve , is it open? is the tube blocked with dry soap or contamination, flusk it with water to be sure.
Apr 23, 2010 | Dewalt 3800 PSI Pressure Washer
What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
Hello awseibel:
  1. attach your garden hose to the inlet (at the back I believe)
  2. Attach high pressure hose with gun wand/nozzle
  3. turn on the water
  4. plug into electrical outlet
  5. turn on/off switch on
  6. spray away
  7. Any non-caustic soap can be used
  8. You must set the machine on low pressure to apply soap.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
Need a part for Homelite model HP3127S pressure washer - 3100 PSI
I lucked out when I managed to locate a local rent it centre who sells and services Homelite equipment. I bought my pressure washer at Home Depot and when I approached staff there regarding my problem, they had no idea if there even was a local dealer who sold/serviced Homelite stuff. telephone enquiries finally led to the rental place who ordered the part for me. I was getting concerned!
Jun 19, 2009 | Garden
Homelite Workforce 2500 PSI 23 GPM Axial Cam Pump Pressure Washer WF80710 Logo
32 people viewed this question
Top Homelite Plumbing Experts
richie46
Gil Shultz
Robert Dean
Robert Dean
Level 1 Expert
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
