Question about AquaSource Stainless Steel 1-Handle Pull-Down Kitchen Faucet 0478000A
Aquasource pull down faucet is leaking from the weephole
Giagni Pompa Stainless Steel 1-Handle Pull-Down Kitchen Faucet
Without seeing the leak and checking further I can't say yes or no.
Nov 11, 2016 | Plumbing
I would like to replace my shower handle and skirt. Are Delta parts compatible with Aquasource?
go to your local plumbing supply they will give you handles and trim parts that will fit in different stiles for your brand faucet
Apr 13, 2016 | AquaSource Stainless Steel Replacement...
Faucet works sporadically even thought solenoid is disconnected
You are saying that the water comes on by itself? What water pressure do you have?
Apr 08, 2016 | Delta Pilar Pull-Down Single Handle...
I have a aquasource faucet and the top button is stuck
Unfortunately, Aquasource is an imported faucet by Lowe's, and parts are not easy to get. You might want to visit a Lowe's and see if they have a replacement diverter unit for this faucet. If you can get one, it should take about 10 minutes to install, then you'll be like new again.
May 08, 2014 | Plumbing
Aquasource 2 handle Kitchen Faucet with sprayer as a fourth piece
I recently installed one and the center is the "holddown" hot and cold were just the hose feeds to faucet. There was a ring in center that had two screws up to base from underneath sink (hex key). Remove center ring and wiggle whole unit up and out. Dont forget to turn off water main and drain lines beforehand. Have fun.
Mar 10, 2014 | AquaSource Stainless Steel 1-Handle...
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
AquaSource Stainless Steel 1-Handle Pull-Down Kitchen Faucet 0478000A Logo
Top AquaSource Plumbing Experts
Donni Steen
Tom Chichester
Are you an AquaSource Plumbing Expert? Answer questions, earn points and help others
