Question about Bosch AQUATAK 110 PLUS Pressure Washer
Detergent doesnt come out - Bosch AQUATAK 110 PLUS Pressure Washer
I have a maytag bravos xl top loader with the water saver i cannot find a detergent that doesnt get rid of the soap it covers my black clothes
powder detergents are generally the reason for that as they use a clay base to carry the active detergent and it is that base that is the problem
Try using a liquid detergent
next try using a wash bag that you put clothes in to put in the wash as that also stops marks and fluff from getting onto black or dark colored cloths
Feb 27, 2017 | Maytag Washing Machines
Why doesnt my washer release the bleach when in soak mode
Hello there:
Yes you can uit will jo the job just fine and the only setback to this is that there are several detergent sensors in the machine that sense the detergent and beklieve it or not they can tell the difference so you may end up with a error code if the product is continously used but if you use the product then after it is done let the machine do a rinse cycle with out any thing in it to rinse out the detergent area and if you can rinse out the detergent area with fresh water ok
hoipe this is verry usefull for yoyu
best regards mike
May 14, 2010 | KitchenAid KHWS02R Front Load Washer
Questions on use of softener and detergent
softener goes in agitator cap. when machine does first rinse and spin it will dispence.i dont think so 4 detergent use, front loader detergent doesnt froth as much.see how u go and reply 4 more help
Apr 03, 2010 | Fisher and Paykel (IWL12)
Detergent does not get released
i have seen a problm perhaps similer to yours on several makes of dishwashers .. some washers have a flip up lid that normally covers the detergent cup .. if the upper basket is in the lower position (if its adjustable) then it blocks the flip up lid from opening ... this seems to be a design problem with several makes (probably all made by the same company ) .. if you put the upper tray in its up position then the door still doesnt open all the way but enough that the detergent gets washed out eventually .. that is if there is no large items just benieth that flip up lid .. if so that can block the water from getting into the detergent cup .. you end up with undesolved detergent still in the cup and in the washer at the end of the rince cycle .. very bad ... you may have a different problem .. for instance if the detergent cup door is not opening at all (bad opening mechanism) .. or if the pump screen is clogged then no water is circulated to desolve the detergent ..
Jan 02, 2010 | Dishwashers
JDB4950 Doesnt clean and i think hard water is the blame
Hard water is tough to overcome in a dishwasher, but there are some things you can do to compensate. First, use more detergent than normal. I have hard water and I put extra detergent in on every load. I just put it on the door when I fill the regular detergent dispenser. Also make sure that you always use rinse aid.
The new tablet detergents seem to work better for hard water, but they are expensive. Try a few different brands and see which one works best. A good way to judge is to look at the heating element and see if it has white scale deposits on it. If you use a box of a new detergent brand and it looks better or worse than it did before, it's a good indication.
Oct 20, 2009 | Dishwashers
D/W detergent door doesnt open during operation.
Most common issue is the bottom rack in backwards, or something else actually not allowing the door to open, physically.
Sep 17, 2009 | Dishwashers
Doesnt clean dishes, seems to be no water coming into machine
There should be about 2 inches of water in the bottom of the DW.  If it is filling but not washing the pump may be bad.  That might explain the loud noise (motor bearing).  I assume that the detergent cover is opening but no water is being sprayed to dissolve it.
May 31, 2009 | Dishwashers
Dishwasher detergent left in dispenser cup on GE Profile dishwasher
there is no solution for it because of its design. i have same GE and same problem. It is happening because top rack is right front of the detergent cup and it is not opening 180 degree while it is washing. it opens only 15 or 20 degree and water just doesnt get in there as much as suppose to be because only water can get in there from the bottom sprayer arm because detergent cup lid is not allowing water to get in the cup from middle and top sprayer like any other dishwasher! i called them so many times and they are just jerks! they blame anyting about my house but their dishwasher. their tec. showed up 4 times and they just keep blaming hot water temrature etc. water temprature doesnt matter if water cant get in the detergent cup, right? but they dont want to admit that because they are like programed robots to give you same answers and just blame you but GE dishwasher. please fill out complain form with Consumer Complaint Department. you should be able to find their address and web site on the internet. Please do so, maybe we can get refund or replacement or something. Never ever buy GE again. Just get a Bosch.
Apr 14, 2008 | GE Dishwashers
Detergent dispenser doesnt open
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Jun 20, 2006 | Maytag PDB3600A Built-in Dishwasher
Bosch AQUATAK 110 PLUS Pressure Washer Logo
29 people viewed this question
Top Bosch Garden Experts
roeb
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
