Question about Weber Summit S-670 Gas Grill
Control knobs switch does not work - Weber Summit S-670 Gas Grill
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
Why doesnt control f150 ford turn from heat to ac on f150 ?
It is possible that your control head is not working properly. The center knob( temperature control ) may be positioning the temperature door to full heat. If you have all of the directional flows and the off position, this is probably the problem. You can remove the control head easily by removing the cover plate by pulling outward evenly at the control face. This will reveal 4 screws that hold the control in place. Remove screws and pull slightly out on the control head(do not pull out far as you could damage electrical connections and/ or vacuum connection. Temperature switch is held on by a single screw on the back of the control. remove screw, turn counter clockwise and pull control from the knob that is now holding the switch in place. Replace switch and assemble back into the dash, locate flat on the knob and the switch, align and press into place.
If you are in the South east Michigan area I will be glad to assist.
May 04, 2014 | 1997 Ford F150 Regular Cab
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
Heater controll switch
Hello, I want to tell you about some of the knobs for the temperature control switch, if that is the switch you are referring to.
The way some of the knobs are made, they have a 1/2 moon shape with a metal clip inside them on the backside of the knob. The 1/2 moon shape is also present on the control shaft the knob fits onto. When the knob breaks and splits, the knob rotates around the temperature control shaft without moving anything. From the driver's view, the knob is normal.
You would need to pry off the knob and inspect it, then rotate the temperature control shaft with your fingers or lightly grab it with pliers.
Jan 30, 2014 | 2004 Ford E-350 Super
Bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
Apr 07, 2012 | Bosch Ovens
The AC only works in defroster mode. If I move the control knob works in the same mode. How can I fix it?
you will have to replace the mode control switch that changes the mode from defrost to vent to floor.make sure the knob is not spinning on the switch shaft as this will cause the problem as well.
Sep 08, 2011 | 1997 Mercury Sable
Honda Accord LX has bad temperature control switch? I just got my A/C recharge with new freons and it is working. Before it was just blowing hot air when A/C is switch on and the A/C control knob turned to...
  1. what year model is accord?
  2. there are several doors in the air box
  3. blend door (hot cold)
  4. mode door (defrost, floor, vent)
  5. recirculation door (outside air)
  6. if the control mechanism is defective. the tech may have reached under the dash and manually opened the blend door.
  7. which control knob does not work mode or temp?
Jul 26, 2010 | 1994 Honda Accord
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
Cycle control GE WHDSR315 top loading washer.
Try pulling the knobs off completely and squirting WD-40 into the switch interior--work the oil in by reinstalling the knobs and moving them around. If no help, then the area behind the control panel must be accessed (pull the power plug), and the control replaced (you should have seen the mounting screws when the knobs were off).
Oct 11, 2009 | Washing Machines
Light on dash board not working
On a Buick Rendezvous there is a very peculiar little switch that pops out of the headlight control knob, simply press th middle of that knob and another rather long skinny knob will pop out. To make the lights brighter turn that knob clockwise to dim turn counterclockwise.
Jun 17, 2008 | 2003 Buick Rendezvous
Weber Summit S-670 Gas Grill Logo
62 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
