Question about DeLonghi Microwave Ovens
Humming noice in advantium speed cook microwave by GE
MicrowaveSvc
  • 9047 Answers
SOURCE: GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
SOURCE: Broken handle
1) Have to remove the door first; top of the oven there are two screws closest to the door, take those out. and the door should lift out
2) flip the door on the table with the handle side down. starting on the handle side there are three clips (top, middle, and bottom) between the outside casing and inside trim. Using a thin screwdriver gently twist starting at either the top or bottom to pod the two casings apart. work your way around the door.
3) You should see one of the screws that hold the handle on (top) but the bottom screw is under the metal casing so you need to remove the screws around this casing as well to get the other handle screw off.
Once you start you will see it isn't as bad as this sounds. I bought the handle for $40.
It is a shame that this is so cheap and breaks off this easily. Surprisingly we have had ours for at least 6 years before the handle broke and we have 3 girls opening and closing this all the time so I guess I was one of the lucky ones.
Hope this helps and good luck
Posted on Jan 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Advantium 120 Oven not working; less than year old!!
No need to scan now...
We got the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
I'm suspecting the keypad or a door switch or switch mount issue.
Also, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 26, 2008
ginko
  • 19396 Answers
SOURCE: GE JE1860 Microwave is not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
rylee_smith
  • 8619 Answers
SOURCE: GE Advantium SCA 1000 top rear cooking bulb blown
Hi
Thanks for using FixYa. First please disconnect the power of the main fuse or circuit breaker panel and remove the screw from the side of the light compartment cover and lower the cover until it stops. Now gently pull the bulb from the receptacle. Raise the light cover and replace the screw and then connect the oven with the mains and switch it on.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 21, 2009
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Microwave lights and fans work but the food does not cook
If the microwave sounds normal, but not heating, then the magnetron is bad and needs to be replaced. If it is making a humming noise, then the diode is bad. I recommend that if it is the magnetron, ou also replace the diode.
Feb 10, 2011 | GE Advantium SCA2001BSS Microwave Oven
Problem with the GE Advantium (model sca1001fss01) Convection / Microwave Oven Everything works except the microwave. It makes a sound like its working, table turns, but does not heat or cook.
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Jan 29, 2011 | GE Advantium 120 Convection/Microwave Oven
The renter threw the tray to adapt the microwave to convection oven. I need to know where and how much a new one costs?
Are you talking about the black round pan? I don't think I have any other parts in my Advantium for speed cooking or convection. I occasionally just use an oven safe dinner plate. Sorry I can't help with replacement parts.
Jan 04, 2011 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
Black Metal Tray for GE Advantium Oven
I just found one for $33.95
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
