Optical connector for external speakers quit working
3 Suggested Answers
  • 433 Answers
SOURCE: External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
Posted on May 21, 2009
easybill99
  • 993 Answers
SOURCE: i have a sceptre flat screen i bought 2 years ago (40") the sound just quit can hook up external speakers?
if the only speakers are defective in ur tv then may be use home theatre audio input pin to audio out pin of your tv to listen the sound
Posted on Jan 11, 2015
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
My tv has no volume, its not on mute
Does this model have a optical out connector?
If it does then maybe the menu option was change from tv speaker to external speaker.
Aug 11, 2014 | Haier L39B2180 39" 1080p LCD TV - 16:9 -...
How to connect 5.1 speakers to ps with asus p5gc motherboard
So you want to connect your Play-Station to 5.1 surround sound speakers through a motherboard, so you can get sound from the Play-Station through the speakers while playing on your LCD TV (LED is something completely different)
You need to get a very specific type of Sound Card to do that.
I would recommend the Creative Sound-Blaster X-FI it is relativity old now, so it will be quite cheap you could get it for about 60 pounds. It is a PCIE card and comes with an external connection box and External Creative X-FI USB sound card dongle thingy.
I would recommend some bettor speakers for this as well as you get 3D crystal sound automatically, unless you turn the settings off. There are options in the EQ for just about every music type and every environment you can think off. Best of all it comes with a remote control. The sound from the Play-Station goes in to the connection box and the sound out from the conection box goes to the TV. There are 6 Audio in 9 audio out on the connection box and a bunch of other connection ports for various things. MIDI, small jack connectors large jack connectors, I-pod connector wireless expansion port, Ethernet port, Fiber optic ports x2, component audio, scart and a bunch that I don't eaven know what they do. ,
Sep 21, 2013 | ASUS Computers & Internet
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
I have just recieved external speakers for compaq 6720s but not sure where to attatch it,please help.
You would normally connect external speakers to a laptop using the laptop's headphone port. The cable coming from the speakers would normally have a green connector on the end and would plug directly in.
If you have a bigger, more complex speaker system then you would need to determine what connections are possible to the speakers and what outputs are provided on your laptop. The most common audio out ports (for PC's, not so much laptops) are SP-DIF Coaxial and Optical. These would provide full digital surround sound signals from your computer but are not found commonly on laptops.
My best guess would be the above green connector to headphone port setup. The rest is a bit optimistic for an everyday laptop.
Apr 02, 2011 | HP Compaq 6720s Notebook
Can i connect pc speakers to the toshiba 55HT1U?
The 55HT1U only has Optical Out (TOSLink) for audio, so you will need an intermediary receiver with optical-in in order to connect up most speaker systems. If you have a higher end set of PC speakers, it may have an optical port on the receiver module or subwoofer. If so, it'll work!
See http://upload.wikimedia.org/wikipedia/commons/4/4d/TOS_LINK_clear_cable.jpg for an example of what an optical cable/connector looks like
Mar 14, 2011 | Televison & Video
Auxilliary audio connection
I don't expect a 2 channel amp would have a digital input such as optical. More likely you would be able to pull analog stereo (red and white RCAs) off the Panasonic and run to the JVC.
Dec 29, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Audio connection
Did you go into menu and change settings to variable output?
Dec 18, 2007 | Hitachi 42HDT79 42 in. Plasma Television
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
