Question about Durabrand Audio Players & Recorders
Durabrand kw rw 4531
How to install
DURABRAND LEDVDR0702 Problemen met opnieuw
If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Nov 01, 2013 | Televison & Video
What MP3 formats does Durabrand CD-96 support?
Do you mean Durabrand CD-968
If you do then this CD player will only play NORMAL music CDs (or CD-R CDs). Not MP3 format This set will not play CD-RW encoded discs.
Jan 30, 2013 | Durabrand CD-96 Personal CD Player
Case 850K dozer. What does code 4531 indicate?
The typical failures of joysticks show fault codes 4533, 4532,4531
Jan 21, 2013 | Miscellaneous
How to install jvc kw-av70bt
Hello I am installing a JVC- kw-av71bt to 2 audiovox headrest monitors. can you tell me the easiest way to run the rca cables from the headunit to the monitors.
Apr 14, 2012 | JVC KW-AV70BT DVD receiver
Using a DVD-RW to create a video and audio format to play on my Durabrand Model 1002 what formats and bitrate do you recommend for viewing on my standard color tv?
You cannot use a DVD-RW disc on a Durabrand DVD player. It is not a compatible disc format. DVD-R discs that have been finalised (as well as shop-bought legal copies) are recommended for this player. As for video and audio bitrates, check out other forums on video to DVD converting and creation for more information. It is down to trial and error.
May 27, 2011 | Durabrand DVD-1002 DVD Player
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
Need to know what formats are supported by the Durabrand 1002 DVD Player.
The complete Detail would be :-
Product MPN MPN DVD-1002
Key Features DVD Type DVD Player Number of Discs 1 Progressive Scan With Progressive Scan Playable Disk Types CD (Audio), CD-R, CD-RW, DVD Video, Picture CD Playable File Formats JPEG, MP3
Audio Surround Sound Dolby Digital (Digital out only)
Connections Outputs Composite x 1, S-Video x 1, Analog Audio x 1, Digital Audio Coaxial x 1
Convenience Remote Control Standard OSD Yes
Other Features Exterior Color Gray
Miscellaneous UPC 017999010026
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | Durabrand DVD-1002 DVD Player
When I install disk, ' No disk' shows on display.
IS the disc on a CD-R or CD-RW (burnt disc) some portable players will not support those types of disc's.
It could also be a different region dvd that doesnt match the region codes of the dvd player. There are no known region hacks for your make and model of dvd player.
Sorry and thank you for choosing Fixya! Post back with more info for further help.
May 18, 2009 | Durabrand 8.5'' Portable DVD Player
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
