My Hotpoint Ultima WT741 is stuck in test mode. Can anyone tell me how to cancel. Carol
  • 15,935 Answers
Unplug for 40 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
WT741 won't spin sticks on 1 min
there is a good chance is locking out on suds
try doing one load with no soap
then dont use anymore than a tablspoon
of any type of sopa
Oct 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf865 washing machine
to take out of test mode you must turn it on while pressing the start/cancel and on buttons at the same time until dOFF appears.
Jan 18, 2009 | Hotpoint Ultima WF865 Front Load Washer
My washing maching wt741 keeps flashing f-12 could u pls tell me the problem, thank you
Hi.
F12 indicates 2 or 3 differant faults.
Try these first.
Press and hold start/ cancel button for at least 3 seconds, and see if jt works.
Make sure hot and cold water taps are turned on and that you are getting water to the m/c.
Select a drain prog, and see if it pumps out o/k.
If all these do not solve problem, then you have a communication error between boards, this entails calling an engineer out.
If it is under 5 years old then you should be covered by the Hotpoint 5 year part guarantee.
Plz rate my solution .Thanks.
Dec 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
if it wont drain check the pump for any blockages and working condition
Sep 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
357 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
