Question about Arris Touchstone Telephony Modem/ TM402G/110
I havea TM402G, top 2 lights steady, 3rd blinking
I'm with TWC, is it them ?
3rd red light has come on . The 2 green lights are constantly flashing do not go to the steady state T hanks for your help Gill Parry
Hi. Could be a few things. Need to take to a repairer. It sounds like a ECU board, but lets hope it just a sencor insde. Dazza REPAIRER
Sep 23, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Where do I find the wires that I apprently need to cross to get the check engine light to flash in order to get the codes?
Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
To clear codes (after problem has been resolved):
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the
black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals. yhis is for the 94, 92 should be the same. have a good day !!
Jun 05, 2011 | 1994 Subaru SVX
My computer tells me that Seagate Replica 250gb is unpluged and that it has not backed up for 33 days - Also should the blue light be blinking or should it remain a steady blue
1.check the backup software and see the schedule status for it
2. When data is be transferred the light should be blinking
When idle the light should be steady.
Oct 11, 2010 | Seagate 3YR WARRANTY BARRACUDA 50GB...
I HAVE A NEXXTECH MODEL;NWKBMCB . WIRELESS MOUSE. I DONT HAVE A DISC WHAT DO I DO?
This will help you in your problem. 1. Turn on your pc 2. Installed the Mouse Driver on your system pc. (NOTE! if it has a CD or DVD Disk included on it ). (But if the product don't have a CD or DVD disk, you can proceed to the 3rd step.3. Plug the receiver to the USB port on your system unit.
4. Plug the battery to the mouse. (follow the instruction for the the battery. cause it contain + sign and - negative sign.
5. After doing the procedure from 1 to 4.
6. Restart your PC (cause some of the system unit need to be restart the system in order to recognize the fresh hardware plug on it).
7. Your Done
Good luck and i hope this steps will help you in your problem God bless.
Apr 07, 2010 | NexxTech NWOMMI Mouse
Wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Jan 08, 2010 | Mitsubishi WD-62327 62" Rear Projection...
TOP LIGHT ON PRINTER KEEPS BLINKING - I'M UNABLE
This should help you. It details what the blinking lights mean and should allow you to diagnose what the problem is.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061319&lc=en&cc=us&dlc=&product=305980
Oct 13, 2009 | HP DeskJet 5550 InkJet Printer
THE ENGINE LIGHT IS BLINKING 10 TIMES WHAT CODE IS THIS
if the engine light is blinking while you are driving that means you havea catalyst damaging misfire
Jul 11, 2009 | 2003 Chrysler Sebring
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Im having problems getting my modem to get online. The light wont come on. All but the online light come on. The online light blinks then all the lights go off except the power light, and the receive...
Your modem is not synching. It could be a number of possibilities, and you're going to have to do some troubleshooting to narrow it down.
  • Verify that your AC, Cat 5, & ethernet cables are connected securly
  • Verify that your modem is not in "standby" mode
  • Power cycle your modem
  • Try a different cable outlet
  • Call your ISP to make sure your modem is provisioned and your service is set up for cable internet.
Nov 06, 2007 | Arris SURFboard SB5120 Modem
Arris Touchstone Telephony Modem/ TM402G/110 Logo
54 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
