Question about DXG Technology DXG DXG-301V Digital Camcorder
DXG-301V CAMERA Message says card is locked how do I unlock it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • DXG Technology Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Apr 20, 2014
3 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: CAMERA
Alkaline batteries are prone to leaking and many consumers face the problem of how to clean up the messy corrosion left in their electronic devices. You should first check with the battery's manufacturer. Many of them offer free cleaning of electronic devices damaged by their leaking batteries. Some of them will replace your damaged item if caused solely by leakage under routine conditions
  1. Verify the type of battery (Alkaline vs Acid based). Avoid eye or skin contact.
  2. Take precautions. Alkaline batteries contain potassium hydroxide, a caustic agent than can cause respiratory, eye and skin irritation. In order to neutralize the leaked alkaline you will need a household acid like vinegar or lemon juice. A Q-tip or old tooth brush can help scrub the leakage from the electrical contacts. Always use household gloves and glasses and work in a well-ventilated area.
  3. Clean acid-based batteries with baking soda (an alkaline) and a little bit of water on a Q-tip or old tooth brush. Never put water directly on the acid.
To avoid future problems, adopt the following practices:
Do not mix and match different battery brands in the same device.
Remove batteries from devices that are being stored.
Make sure electronic device is completely dry before trying a new battery.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
SOURCE: DXG-301V Power won't stay on
laistrop,
The fact that your camera was not used for a year and assuming the batteries remained in the camera (uncharged?) after that long a period of time, it would be very likely the batteries have deteriorated and may need to be replaced. The first thing to try is charging the batteries if you have not already done so. Plug in the charger and allow at least 12 hours for the batteries to charge. If the camera still will not work, the original batteries have very likey lost their ability to hold a charge and will have to be replaced. To test this, without spending too much money, try inserting 4 Alkaline AA batteries in the camera (observe the battery polarity marked on the flip-top battery cover). If the camera works, you should replace the batteries with fresh NiMh rechargeable batteries and charge them before you attempt to use the camera. Allow at least 12 hours for the initial charge unless the battery manufacturer suggests otherwise. I would not recommend using any form of "rapid" or "quick" charge rechargeable battery. If you do, you will be paying extra for a convenience you will not use, unless you plan to use an external quick charger, since the camera is not equipped to support rapid battery charging.
Rega
Posted on Mar 13, 2009
Manual
It doesn't. The DXG-301V uses standard AA batteries, either disposable or rechargeable. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate charger.
Jun 23, 2013 | DXG Technology DXG DXG-301V Digital...
Camera says card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 25, 2012 | DXG Technology DXG-518 Digital Camera
How to operate the camara
Please click here to download the manual of the Camera. You can go through the manual to get the detailed instructions to use the Camera.
Thanks for understanding.
Mar 05, 2012 | DXG Technology DXG-301V Digital Camera
What is largest memory card I can use with the DXG-301
According to page 14 of the manual, you can use MMC and SD cards from 4MB to 512MB.
Jun 16, 2011 | DXG Technology DXG DXG-301V Digital...
I need the softtware the cd-rom with drivers for DXG-301V
You may download the driver here.
You may want to consider NOT using a driver at all. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 12, 2011 | DXG Technology DXG-301V Digital Camera
I am getting message "card is locked" so how do I
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 09, 2011 | DXG Technology DXG-305V Digital Camera
laistrop,
Rega
Feb 17, 2009 | DXG Technology DXG DXG-301V Digital...
Video Cameras Logo
Top DXG Technology Video Cameras Experts
Jose Ma DM.
Jose Ma DM.
SHARCNET-USA
SHARCNET-USA
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
