Question about Sony Lands Phones
Tam-50 does not answers - Sony Lands Phones
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Tam full?
What model Telephone Answering Machine (TAM)?
May 09, 2013 | Binatone Lands Phones
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
My Binatone answer machine shows seven calls listed. How do I delete them?
If it is the i-tam 50 it can be fiddly, you'll need to tap the del button repeatedly whilst the message is playing.
Feb 16, 2011 | Southwestern Bell FA-970 Digital Answering...
When having phone conversation fax goes off...how do I fix this?
On fax machine there should be a answer mode settings on them. For an example phone, fax, or tam mode. The tam mode is when the fax machine will pick up if there is incoming fax automatically if hooked up behind the answering machine. Try doing some troubleshooting, by changing the it to phone only, and see if that works. Then if that works try the tam mode.
Aug 11, 2009 | Canon MX700 Office All-In-One InkJet...
Instructions for setting up Sony telephone answering machine model TAM 100
The instructions would be :-
http://www.fixya.com/support/p121269-sony_tam_100_digital_answering_machine/manual-15443
Thanks.
Jul 25, 2009 | Sony TAM-100 Digital Answering Machine
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Can't receive fax when ansering machine is on
on the side of the machine you have a ringer switch see if that works.
Mar 12, 2008 | Sony TAM-100 Digital Answering Machine
Lands Phones Logo
19 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
