Question about Weber Genesis Silver B Grill
Q2200 weber low flame
Low flame, no heat
SOURCE: My weber Baby Q grill has a low flame.
Agree with rjmbridge. I called the Weber support people and was told that there is a built in safety feature on the regulator that will cause the flame to burn at a low setting if the gas within the extension tube to the large tank and regulator is not allowed enough time to equalize. They suggested turning on the gas from the tank very slowly, allow about 2 minutes with the temperature control knob turned off, then turn the temp knob on and light. This worked for me.
Posted on Aug 09, 2008
SOURCE: just bough weber Q200 grill. Is it normal that the
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Posted on Aug 23, 2009
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have low flame on a weber gas grill. What are
Well it coulbe caused by these newer type propane tanks with the anti tip safety device installed inside them. To rectify you simply remove the tank to clear the pressure in the line and open all valve son the grill. Then close all valves on the grill and reconnect the tank. Then open the valve only just enough to allow gas into the grill, just crack it open a hair. Retry.
Posted on Oct 14, 2009
cadesertmax
  • 274 Answers
SOURCE: Weber Q 220, low flame and temp
Try replacing the regulator
Posted on Jan 10, 2010
Does low water pressure influence water being heated? The flame does not ignite. Gas bottle(19 kg is more tan half full).
no--- as low pressure is what turns the gas on to heat up
high pressure turns the burner off
call a gas fitter to determine the real reason the flame is not igniting
Apr 09, 2017 | Heating & Cooling
My fire burns with an orange flame and is either on full heat or low heat, no inbetween so can't ajust heat properly, can I fix it myself and if so, how.
Don't know whether you can adjust to somewhere between low and high. However, the flame colour that you describe seems a bit off. I would have expected it to be bluer. The air/gas ratio might need adjusting and before you ask, I have no idea!
Jul 09, 2015 | Heating & Cooling
Very small flame takes like ten minetes for flame to get high
The reason the flame in the oven is so small and takes for ever to heat up is because the oven igniter is weak and can not open the gas valve very much so hardly any gas flows resulting in a low flame size. By replacing the oven igniter the flame will be full size and heat quickly.
GENE
Oct 16, 2011 | Sears 61301 Gas Kitchen Range
Low flame - doesn't heat enough
Hi, Patty. The low burner flame on a natural gas grill an be caused by several things.
1. The gas line shutoff valve is not fully open.
2. The burners are clogged and need to be removed and properly cleaned
3. The venturi valve(s), which has spider screens may be clogged.
The things listed above are the top 3 reasons for the low burner flame problem on a Natural Gas Grill.
To help you accomplish the cleaning of the burners and the venturi valves, I have included a link to your Owners Manual, that you can download & print for future reference. It has detailed instructions and diagrams in the Maintenance section, that will show you how to accomplish this.
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89961_022811.pdf
Hope this helps you to solve the problem. Please let me know. Thanks and Happy Grilling!!
May 14, 2011 | Weber SPIRIT E-210 (NG)
My Weber Q grill worked great for 5 years but now it won't light on one corner and I can't get a high flame on any part of the burner. Even on "high" the flames are small & blue and the heat level is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 26, 2010 | Weber Q Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
Low flame
Try putting on a new regulator
Nov 23, 2009 | Weber Q Grill
Flame is low
try opening the tanks slower so the overfill protection device in the tank won't kick in and restrict the gas flow.
Nov 10, 2009 | Weber Genesis Silver A Grill
Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Sep 04, 2009 | Empire DV-35 Heater
Weber Genesis Silver B Grill Logo
233 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
