Question about Sony DCR-DVD608E DVD Camcorder
My pictures won't rotate when they appeare on the camera
My Camera will not let me zoom, and my buttons are no longer working. Can you please help me?
4 Suggested Answers
ttech
  • 139 Answers
SOURCE: zoom button does not work
Go get some Electronic Contact cleaner and on the Side of the Toggle switch spay a little bit in the front and rear of the switch ,Make sure the Battery is out and spray the rocker up underneath to get to the Tact switch,Rock the rocker back and forth several times to clean the switches,The Contact clear will dry quickly,After dueing this let dry for 5 Min put batt and try it good luck Let me know if this works ttech
Posted on Jul 24, 2007
jerryg50
  • 1667 Answers
SOURCE: picture shakes when I zoom
I don't know how you can easily tell the spec for the anti-shake is working on your camera. There is a specific specification for how much it can compensate. There is a factory spec that specifies that with a specific lens magnification ratio, the camera can be moved a specific number of arc-seconds and display within a specific amount of movement error. At home it would be impossible to do a technical evaluation of this feature.
What you can do as a user is to read the instruction manual about the option and see how to make sure that it is turned on in the camera's menu section. It is possible that your model may not have the feature. This you have to check in the spec sheet that came with the camera.
When the anti-shake is turned on, you should see the picture appear to be more stable than when it is turned off. With high zoom settings, it will be less stable looking than with wider angles of zoom. It does have its limitations.
Professional photographers normally don't like the anti-shake feature for shooting videos. For still pictures it is a good feature if you want this type of performance. This is because with moving video taping when the camera is being panned in small motions, the smoothness of the pan is taken away. The stabilizer starts to work at the beginning of the pan and then it gives out in sort of stepping actions. This can create a sort of jerking type of pan motion in the pictures.
Jerry G.
Posted on May 02, 2008
ginko
  • 19396 Answers
SOURCE: Camcorder zooms by itself.
More then a problem with the main board, or with zooms gears it looks like a problem with buttons.
If you have already taken apart the camera, grab a multimeter and thest the output from button board. I am sure on one contact you will find some continuos voltage that is what activates the zoom.
Here is Sony spares in UK: Sony Genuine Spares (UK)
Posted on Jul 24, 2008
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Dropped camera leads to zoom error and blurry pictures. HELP!
Your lens was damaged and probably needs service. This could be expensive so get an estimate first to help you decide what to do.
Nov 10, 2011 | Fuji FinePix S1000FD Digital Camera
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
My SD800IS was working fine while in the very hot/humid environment of Yap. I took it out of my air conditioned room and went to take a picture almost immediately. The view finder, the LCD image and the...
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
May 06, 2011 | Canon Cameras
I have a new pc and would like some software for my camera which is a olympus c-920 zoom onto my computer it is running on windows 7 help please would be good
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Oct 14, 2010 | Olympus Camedia C-920 Zoom Digital Camera
My Panasonic DMC-LZ3 camera appears to have locked up
Make sure the scene mode dial is correctly "clicked" into a choice. You could also try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 24, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
How do i zoom
1. Toggle the MODE button to camera picture and press the SET button
2. Compose your image while viewing the LCD monitor
3. Press the ZOOM thumbnail button with the magnifier picture to activate the digital zoom.can zoom images up to 5 times
4 Press the shutter button to capture the ZOOMED image
Hope this helps, there wasn't a date on your e-mail so not sure when your Holiday was.
Good Luck
Missy S
Sep 03, 2008 | Vivitar ViviCam 3780 Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Malfunctioning of Nikon 2100
I had the same problem.The shutter button is faulty and is always half pressed - auto focus is operational (this is the step before actually the picture is taken. Try to clean it up with some special electrical contact spray. if this does not work - need to replace it - Not a simple job for the novice. You might need to take the camera to a service center for a spare on-off-expose button. I had an old faulty camera where I took the button from it. That solved the problem.
Nov 27, 2007 | Nikon Coolpix 2100 Digital Camera
Sony DCR-DVD608E DVD Camcorder Logo
10 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
