Question about Sportline 1010 Duo Heart Rate Monitor
Accuracy in readings
I just bought this for my wife. We're having trouble getting an accurate reading. Just sitting still it reads anywhere from 65 to 85 beats. She mowed the lawn and it shot up to 172 and she wasn't even breathing heavy. Is there a trick to getting an accurate reading?
Accuracy after decimal?
Perhaps ten times more accurate than you can read. Lots of stopwatches go to one thousandths of a second, while the person pressing the buttons has a reaction time that can vary from one tenth to half a second. And every time the reaction time changes. So if it is not electronically is started and stopped, don't bother the accuracy of the watch.
May 08, 2014 | Casio Atomic Timekeeping Waveceptor Watch...
Do you check the oil level when the engine is cold or hot
If you check it cold with the engine not running you get an accurate reading of the amount of oil in the sump; otherwise oil will be lubricating the engine and the dipstick reading will be inaccurate
Jan 05, 2013 | 2007 Subaru Forester 2.5X L.L. Bean...
My weight is not accurate. I weigh 260+ and the scale reads 245 to 249 and is inconsistant. I just replaced batteries (CR2032)for the second time
Very few electronic scales are accurate as they are a function of a resistance measured against a voltage. They may be accurate when you buy them, but over time the electronic components decay and read differently as the components are cheap 10% type resistors and capacitors and cannot hold their specific values over time.
If you want accuracy, you will have to get a balance type scale that can be calibrated on site.
May 17, 2011 | Taylor & Digital Scale Lithium Scale
How to check youself / blood pressure for accuracy i get to different reading the first time then upon checking for accuracy the second time the reading is always different
Hello Dear
All Digital equipments vary in its reading. To get the accurate reading take three readings one after the other and then the average of the reading is the accurate one.
Usually the readings varies plus minus 2 or 3 to the accurate reading.
Hope the answer will help, please rate the answer.
Best wishes
Feb 23, 2011 | Lumiscope 1080 Deluxe Auto Blood Pressure...
I need to know about the degree in precision for when using an ac and dc voltage for a multimeter
I dont think This particular model is a True Rms Type . So you will not get accurate reading as of a True RMS Multimeter in AC . But in DC you Should atlest get an accuracy of 0.015
Please Rate My answer well and Support me !!!
Nov 22, 2010 | Mastech Feature Digital Multimeter BuiltIn...
Humminbird 798 has erratic gps speed readouts at slow speeds between 1 and 3 miles per hour. Speeds bounce up and down between 0.1 and 3.0 mph even when sitting in the boat in my driveway!
I had the same problem. I talked to 3 different technicians on the Humminbird support line about it. All 3 of them confirmed that this is how their technology works. They ping the GPS satellites continuously, and at low speeds the GPS accuracy causes the speed measurement to fluctuate wildly. It smooths right out when you go faster than 3 MPH, since your boat moves far enough at that speed that the GPS accuracy is no longer a problem.
Seems like they could easily overcome this issue by averaging GPS readings over a longer time period at low speed (i.e. give the boat enough time to move far enough to eliminate the accuracy issues), but they don't do that.
It was a big issue for me since I do a lot of trolling at low speed and need an accurate speed indicator, so I returned the product and bought a Lowrance instead. Lowrance doesn't have this issue.
Oct 13, 2010 | Humminbird 798ci SI Combo GPS Receiver
I purchased a new LR 559 Callaway golf rangefinder from a QVC auction. The problem with it is it isnt even close to accurate. I have a measured archery range back to 65 yards and the rangefinder is way off...
its a piece of ****, that happens when you arder through qvc. When you arder electronic devices for weights or measurements, first you must know exactly what you are looking at, make, model, and series,,, then read all of the reviews you can,, then go to a pro store-- (like our shop we are a pro archery shop) we refuse to work on peoples bows they bring in that they bought online, because half the time they recieved something that they did not order, they dont look like they did in the picture that the seller posted... always read reviews and ask the professionals.... I would return the item even if it was an auction, if you cant return it then ebay it-- but be honest when you post descriptions of the item, and the problems that you may be experiencing, trust me the buyers will appreciate it...
Sep 11, 2010 | Nikon Unisex LR550 Rangefinder
Why is my coordinates off by 50-80ft. why? Side by side comparision of another gps shows my gps is not accurate.What do I do?
Your GPS is accurate for that brand. I have a Lowrance I Finder Pro. We could both put in the same coordinates and come up in different locations. It is just the way the different GPS's get their signal from the satellite. I use my GPS most of the time for a sport called Geocaching and so when I am given coordinates and don't find the thing I am looking for I so about a 30ft-60ft search around where my GPS took me. So yours is basically doing the same thing. I wouldn't worry about it......it's just the way the different models receive the signal that thows them off a bit. If you went out and got a set of coordinates and then I put those same coords into my GPS I would arrive at a completely different location as you. All is well....no need to worry.
Aug 07, 2009 | Garmin eTrex Legend Cx GPS Receiver
RE;ford e-250 van 2000 (yr) reset trouble code
yes but it will be in a memory code.
Feb 28, 2009 | 2000 Ford Econoline
Sportline 1010 Duo Heart Rate Monitor Logo
Top Sportline Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
