Question about Toaster Ovens
Replace grill element on ekc5544 cooker - Toaster Ovens
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Dec 10, 2016 | Hamilton Beach Toaster Ovens
Could you send me a manual
sorry but we have nothing here to send and that is not an option for you . this is an advise site mostly .look on google.com under make model and manual
Apr 23, 2015 | George Foreman , Baby George Rotisserie...
Need heating element (upper) for GE168947 toaster oven
You should be able to install a new replacement element or a used element from another GE168947 toaster oven.
Jul 03, 2012 | Toaster Ovens
Cant remove warped top grill element
normally this is quite simple 2 screws hold the element on ..If its warped the you could cut it out with a junior hacksaw....Try not to breath in the dust from same...
Mar 31, 2010 | Toaster Ovens
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Dec 15, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Toaster Ovens Logo
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
