Question about Speed Queen AES28AWF Electric Dryer
Blower wheel makes noise whenstarting - Speed Queen AES28AWF Electric Dryer
Making loud noise
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Apr 30, 2015 | Dryers
Dryer making chirpy squeaky noises then it stopped. Noise was intermittent
DRYER MAKES NOISES.
The blower:
The bearings:
Mar 10, 2015 | Dryers
Asko dryer make a banging noise
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 02, 2014 | Asko Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
Whirlpool Cabrio Dryer MOD WED5600XW0 making whirring noise
take the bottom panel off,you'll see a metal duct that the lint filter slides down into,there's a blower wheel behind the duct,if the wheel cracks or gets loose where it connects to the motor shaft it can make this sound,start the dryer and listen to see if the noise comes from there.if you can't tell unplug the dryer,pull out the lint filter and then take out the screws that hold the metal duct in place and remove it,now you can see the blower wheel,spin the drum by hand and see if the blower wheel moves with the drum and belt.if it looks fine stop spinning it and grab the wheel and see if it feels loose,if it is you will be able to tell.also while you have the duct off clean it out,you should take it off at least once a year and clean it out,then vac out the cabinet and blow out your vent line with a leaf blower if it's long,just remove it from the back of the dryer,stick a leaf blower into the vent line and blow it out.go outside first and make sure the outside duct is clear,no cage or anything that will block the lint from blowing outside.if the blower wheel is ok then the noise could be the belt roller or belt pulley,thety sell a kit with all the parts together but usually when someone says it's making a whirring sound it most likely is the blower wheel.hope this helps.
Nov 13, 2013 | Whirlpool Dryers
Blower wheel was making noise so purchased a new one & installed it. About 2 days later dryer begin to make same noise again. What is causing the blower wheel to go bad.
perhaps it wasn't the blower wheel - what kind of noise? how did you come to the conclusion it was the part you replaced?
Oct 06, 2013 | Washing Machines
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
My duet dryer makes a loud noise when i push statr and doesnt turn...
What does the noise sound like? Is it a humming noise? Might be your motor. before we assume that, Take the bottom panel off and the blower wheel housing should be there. Take off the srcrews that hold it in and make sure there is nothing in there blocking it from turning. follow the filter chute down. The part you put the screen into. make sure nothing fell in there and is blocking the blower wheel from turning because the motor shaft is screwed into the back of the blower wheel. The motor is what spinns the blower wheel and if something is blocking the blower wheel then the motor wont operate and your drum wont spin. try checking tha out.
Aug 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
York P3HU Gas Furnace Blower wheel makes noise and vibrates
yes you have a bad blower wheel the fins are crimped to the disks, if you can take the blower assembly out just watch the wiring and take the motor out of the center of housing away from blower wheel and when taking out the wheel remember the diriction of the wheel
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Speed Queen AES28AWF Electric Dryer Logo
15 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
