Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Works in Ubuntu, not in XP
I have a my passport WD 320GB hard drive. I've used it quite a bit on my laptop, which is running ubuntu, and backed up quite a bit of data to it. But when I tried to plug it into a computer running xp, it ran the little bubbles in the bottom right hand corner of the screen saying "your hard drive is now ready to use", but it won't show up in my computer. I've tried it in Ubuntu since that happened, and it's still fine there.
  • 107 Answers
Your problem is that you have formated it with Linux file system if you want to use it on Windows you need to reformat using Fat32 or NTFS file systems. You can also use
Explore2fs
Good Luck!
Posted on Jun 27, 2009
Maximum hard drive
If you run Windows XP or newer, Linux, Ubuntu or Mac then you are not restricted to size. The larger the hard drive the longer it takes for windows to check all of your files as it boots up.
Jan 10, 2014 | HP Compaq Presario V2000 Notebook
The operating system that I used in my computer is XP.How would I install ubuntu operating system on my laptop?
the Ubuntu ISO that you choose for you pc needs to be selected (x86 for normal 32 bit pc or x64 for 64bit devices ) download the ISO and burn to cd or DVD your choice. when you running XP insert the disk and it gives you a option to install aside xp or to partition the drive to add ubuntu separately or to do a clean install ( wiping everything ) or boot up with it and it will help partition the XP drive to install alongside xp to do a dual boot.. this can be easy or hard id get a tutorial on this. but the clean install is the easiest and best it wipes out the drive and I'm almost sure everything will work when it comes on look up the model laptop and ubuntu 11.04(newest ) all my devices work all the time and the software is awesome as well as free and virus free
good luck google installing ubuntu for noobs
Oct 01, 2011 | Canonical Ltd. Ubuntu
Can only see one WD Passport 320GB drive at a time.
This is most likely a classic case of them trying to occupy the same drive letter. If you open disk management Start > Run > type 'diskmgmt.msc' and you should see them both there - One with a drive letter and one without, simply right click on the drive which doesn't have a drive letter and select 'change drive letters and path...'. Change the drive letter to something you know doesn't really get used and they should both appear in my computer.
Hope this solves your problem.
Jan 12, 2010 | Western Digital Passport 320GB External...
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
May 28, 2009 | Western Digital 500GB My Book Pro-External...
I have a WD Passport drive that I want to use through a Targus mini USB hub. The Passport drive has power, but it will not install through the hub. Apparently wants a driver and apparently they don't have...
The reason your full sized drive works fine and the passport doesn't is that the full sized drive has it's own power supply and only uses the USB for data transfer. The Passport drive requires much more power from the USB to spin up, so, if you want to run it through the USB hub at the very least you will need to replace the USB hub with a powered one.
As for a driver, you don't need one to use the passport on XP that's why you can't find one but the Passport does require a dedicated port(2 for Amperage on some systems) or will need to be plugged into a powered hub or it simply won't get enough juice to fire up. That is the reason it won't show up.
In short, buy a powered hub, or plug it in direct. Nothing else is likely to work.
Hope this helps figure it out
Chris
May 07, 2009 | Western Digital Passport 320GB External...
Ubuntu is not starting...
Uninstall Ubuntu and try Ubuntu 32bit version.
Vista sometimes does not get along with other software,or O.S
Jan 30, 2009 | Compaq Presario Notebook
320GB WD passport essential works with XP os but not with vista
both of my vista machines worked perfectly... i am not using the software that came on the drive. as a mass storage device it works perfectly.
Jan 29, 2009 | Western Digital Passport WDXML800UE...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
238 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
