Question about Lands Phones
Simolink troubles Siemens Simolink cable not connecting to Scanner
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
No electricity on screen. How do I connect LCD doesn't work
Which is cheaper:
* spending $50 to $75 to have a qualified technician "trouble-shoot"
* spending $50 to $100 to buy a used 17" (not 15") LCD monitor?
Jul 31, 2010 | Fujitsu Siemens Siemens Silver Line S5 15"...
Does not detect my sanner and the other programs do ?
good day. you may have a problem on the usb cable connecting the scanner to the pc. try getting a new cable for it to work properly. hope this helps. have a nice day
Feb 04, 2010 | Corel Paint Shop Pro® X Full Version for...
Connect 6520 to hard drive
This router is designed to be connected to your computer . Your drives are also connected to your computer. But you can set up a LAN to access your other computers and/ or drives on a network
Oct 22, 2017 | Siemens SpeedStream Modem (4100) (SS4100)
Scanner is not connected (UMAX Astra 1220S)
Ensure the scanner is powered on. Change the USB cable. Use the correct driver depending upon your OS, XP or Win 98 or WinNT.
S. Mohan
Nov 23, 2008 | Umax Astra 2200 Flatbed Scanner
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Rebooting problems fujitsu siemens
I WAS GIVEN Gateway model: FMN 400C I WANT TO MAKE IT WIRELESS ? IS THIS POSSIBLE ? HOW AND WHAT WOULD I NEED TO DO ? I HAVE BOUGHT AND INSTALL A NEW WIRELESS CARD..STILL HAVING TROUBLES WITH MAKING CONNECTION TO THE MODEM.I was on the phone with cable people.Yes I have wireless set up already.Where can i find instruction Manual? I can get green light on the card sometimes.Socket for cable either net wire be loose?
Mar 24, 2008 | Computers & Internet
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
