Question about Honeywell Dryers
Hy108tgt how do I remove grille and filter to clean
    New Friend:
  • 18 Answers
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Posted on Aug 07, 2016
How do you remove the front plastic front piece to clean the "grille" behind the filter?
Has to come off somehow. Maybe there are clips holding it in place. Was put together by man so it can be taken apart.
Sep 20, 2015 | Heating & Cooling
Removal of front cover, so filter can be cleaned
On my air conditioner the filter slides out from the top of the air intake grill. It looks like part of the grill but look closely you should see the seam across the top of the grill. You don't have to take the front grill off.
Jul 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
How do I take apart the air purifier to clean it? I have a honeywell HTT-022 unit and it needs cleaning
Here is the owner's manual:
http://www.kaz-canada.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=ee97a4e6784448b6f57acddb2f29a817
It says first to unplug the unit.
While pressing on the two notches along the front of the grille, pull the grille toward you and remove it.
Gently pull down on the top filter frame and pull forward.
Remove the protective wrap from the filter.
Place back into the air purifier housing and snap filter grille into place.
(This is verbatim from the instructions)
Feb 21, 2011 | Vacuums
I want to take my ecoquest fresh air apart to clean it, but do not know how, i have misplaced the manual
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions on the sides of the back grill that has a plastic tang that hold the back grill to the machine. Press the back grill inwards to allow the tangs to clear the sidee and the back grill should now be easily removed. Remove the two thumb screws on the top corners to remove the filter. Once the filter is removed, then you can remove the purification plate and remove the two screws that hold the RCI cell. The RCI cell and filter can be cleaned by vacumming out the dust and dirt.
The purification plate can be cleaned with a old toothbrush and a water and amonia solution. Scrub the metal grid with the toothbrush. Do both sides and then rinse with water, allow it to dry completely before reinstalling the plate. After every part is cleaned reassemble the purifier, and plug it in. Then press the reset reminder button on the front of the keypad to clear the "perform cleaning" message. This message will appear again after the purifier runs for 30 days to remind you to clean the purifier. Hope this helps you.
Oct 09, 2010 | Ecoquest Fresh Air Air Purifier
How do you clean the filter?
remove the front grill that has the filter fittted on the grill end. remove and use a fine brush and aided with an air jet blow into the filter and remove off all the dust that is on it.
You can also use good detergent to wash off dirt and dry the filter but without any harsh brushing.
Now set this back but make sure to clean the inlet of the cooling
fins.
Sep 01, 2010 | DeLonghi CF210 Portable Air Conditioner
The grill on the unit has a lot of moisture and it
Couple of things, are your filters clean??? If not clean them It also sounds like a lack of refrigerant, so get the system professionally checked and re-gassed.
I take the time to help, so please rate me!
Jun 27, 2010 | Fujitsu 24C1 Air Conditioner
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
How do I change the water filter?
changing the water filter is a easy job on most ref . how ever there different models / so i will look yours up / i wil get back with you in just a min . _______ I back the part # 4396508 is located down by your toes. in the grill . .remove the grill and 1/2 turn and pull out . change the filter . you don't have to remove grill but those thad do will be able to clean the coil. ( very important . good luck hope this helped **** ..
Jan 06, 2010 | Whirlpool GS5SHAXN Side by Side...
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
Air filter
If the bucket is removed, the filter is accessible from just behind the lower edge of the grill...there should be two tabs that you can use to pull it down from behind the grill...they sometimes have clear blue tape holding the filter in, so remove the tape or pull hard and the filter should drop down for cleaning.
Oct 27, 2007 | Kenmore 54501 Dehumidifier
Dryers Logo
106 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
