Question about Air Tools & Compressors
Keyless door lock - Air Tools & Compressors
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCodeā„¢ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In Ā· Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
What is wrong with my hummer H3 locks. Neither the keyless remote nor the lock button from the door can open all the passenger doors. When I press the Keyless remote or the door lock button, it open the...
Check the relays in the fuse box. It appears that the solenoids for locking the doors are working correctly. However it appears that the lock solenoid is not working properly.
Jan 30, 2015 | 2007 Hummer H3
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
Keyless entry on honda civic 2006 not working
The keyless entry is designed to work with the doors closed (closed - not locked). If the door ajar sensor thinks the door is open the keyless entry is disabled. When you manually lock the door it might tighten the door just enough to activate the keyless entry. I would try slamming all the doors closed and then see if the keyless entry works. If it still wont work have the wiring checked on the front door lock.
May 12, 2009 | 2006 Honda Civic Hybrid
Air Tools & Compressors Logo
22 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
