Question about Emerson EM227 Bluetooth Headset
Bluetooth m228 can not play music from galaxy s5
I have galaxy s5 lollipop android. i bought sd card to save files on it. but my problem is that it plays some music or video after save. i change another card,same problem. can someone help me?
Do you mean it plays some music or video but can't play other music or videos? If my understanding is right, you'd better check whether the card works on another phone. If it works, you can try installing a third-party player to your S5.
Good luck.
Oct 20, 2015 | Samsung Galaxy Cell Phones
Listen music
frnds...ungaluku Nokia BH 104 la songs kekkanuma..android appsla mono Bluetooth router download pannunga...easya songs kekkalam...enjoy..
Oct 16, 2013 | Nokia BH-104 Bluetooth Headset
Iphone 4 music plays via bluetooth but not via dedicated cable connection
It would seem that the headphone jack is damaged. Double check that the wired headphones do work.
May 08, 2011 | Cell Phones
Want to know how I can listen to my music through my bluetooth
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
Jan 17, 2011 | Cell Phones
Same exact problem- music player works fine with headphones
If you had a bluetooth device connected and it did not disconnect properly then the phone may be trying to play the sounds to the bluetooth and not the speaker, Turn the phone's bluetooth off and then on and it should work. Also, if you look at a sound file or video file it will show the bluetooth symbol next to it, which means that it is playing to bluetooth and not the phones other outputs.
Jun 09, 2009 | Samsung Eternity Cell Phone
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
May 07, 2009 | Skull Candy SC-INK'D/Blk Consumer...
Motorokr S9-HD headphones does not pplay music with Fusic phone
On your smartphone, you need to enable the bluetooth wireless headset settings. There may be a seperate setting on your bluetooth options for enable wireless headset and enable wireless handsfree.
You may also want to check and make sure the volume is turned up all the way on the smartphone media player and on the headset.
Jan 12, 2009 | Cell Phones
Music won't play on my bluetooth headphones.
If your handset does not support stereo music on blue tooth headset, then you can not hear music on blue tooth head set. However you are able to answer and make calls through blue tooth headset.
Jan 08, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Aug 04, 2007 | Samsung SGH-X830 Cellular Phone
Emerson EM227 Bluetooth Headset Logo
14 people viewed this question
Top Emerson Radio Communications Experts
J.D. Browning
J.D. Browning
Are you an Emerson Radio Communication Expert? Answer questions, earn points and help others
