I need a manual (user and service) for a Proton 1100 preamp. Any help would be appreciated. thanks. kjmacmillan (at) edu (dot) pe (dot) ca
2 Suggested Answers
  • 4234 Answers
SOURCE: I need a schematic for a Proton 1100 Preamp.
I don't believe that these are available electronically. What is the problem that you are having? Perhaps we can work you through the repair.
Dan
Posted on Jun 29, 2009
How do you connect a proton d540 amplifier to a Marantz sr45 ?
Why? The Marantz receiver already has an amp and the Proton is an integrated amp. But if you want to use the Proton as a preamp with the Maranyz you could remove the jumpers on the back of the Proton then connect RCA cables from the Proton's Pre Out to the Marantz's Tape In but I really don't see why.
Sep 18, 2015 | Audio Players & Recorders
Does a Technics SL-J90 have a preamp?
This player does not have a pre amp. I'l send a link for the service manual, but don't try to change anything.
The element you use, is a MM or a MC (Moving Magnet or moving coil)
The MM gives about 100 times higher voltage, but still less than any modern amplifier can handle. The MC element only gives something between 0,2 and 1 mili volt.
Then if your amplifier does not have a RIAA correction, your preamp should have.
Just google around for MM and MC elements. My guess is you have the original MM element.
TECHNICS SL J90 Service Manual
Dec 27, 2014 | Technics Audio Players & Recorders
Preamp manuals
The Onkyo web site, most probably
Sep 07, 2014 | Audio Players & Recorders
Samsung ht c350 region
It is not a user replaceable or serviceable part. It amplifies low level sighnals to an intermediate level.
Apr 24, 2014 | ATI Audio Players & Recorders
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
What are the RCA plugs for on the dxz855mp
Hi, your head unit has 6 RCA preamp outputs and 2 RCA sub-woofer preamp outputs. These outputs connect to amplifiers if you care to use them. You can read all the specs and download the users manual at the following URL:
http://www.crutchfield.com/S-lAJZzNi4tYJ/p_020DXZ855/Clarion-ProAudio-DXZ855MP.html#details-tab
Please let me know if you have more questions.
Dec 13, 2011 | Clarion DXZ855MP CD Player
How do I connect a Mirage Omni s-10 Sub Woofer and a Parasound Model 2100 Pre Amp to the NAD C372 Amplifier?
You DO realize the preamp is duplicating stuff in the Nad C372, right? This Preamps adds nothing but PHONO connectivity and control. That's why they're called "preamps".
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C372-Amps-manual/id/8043dj592/t/2/
http://www.retrevo.com/support/Mirage-OMNI-S10-Subwoofers-manual/id/14438ag918/t/2/
Model 2100 Picture and article:
Use the Sub Out pair on the Preamp (joined by an RCA Y-cable) for the Sub Input on the sub (duh):
http://www.hometheaterhifi.com/preamplifiers/362-a-secrets-preamplifier-and-power-amplifier-review.html?showall=1
Run RCA from the Preamp Main Out to the C372 Aux In to hear any sources attached to the preamp.
Or, if you don't NEED the preamp because you don't have a turntable,ditch the preamp and connect the sub using the speaker outputs on the NADS, according to the manual.
Mar 08, 2011 | NAD C372 Amplifier
Carver CT-28v Tuner preamp - Has a hum/buzz (soundls like a ground loop) that is heard as soon as the unit is turned on. Does not increase with volume, just stays the same and is continuous. Changing...
Reverse the polarity of the AC plug and try it. Is there a headphone jack on the preamp? Try headphones with the preamp standalone without the amp attached.
Are you sure the preamp is the problem? I assume you also have an amp or you wouldn't hear anything. Power up the amp with nothing but speakers attached. Hum??? It's in the amp. No Hum? Attach just the preamp with no external components. Hum now? It's the CT-28. Turn it off an exercise every switch and knob throughout its range numerous times. Try again. Still humming? Manipulate source selections, Tape Monitor, everything.
Nov 19, 2009 | Audio Players & Recorders
Dan
Jun 29, 2009 | Audio Players & Recorders
Sony Reel to Reel preamp board.
Did you ever get your schematic? I recently got the Model 260 and it has the original owner's manual. I could try scanning the page for you, if you still need the info (if you think that would help you).
--Dave
Mar 28, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
128 people viewed this question
 Grubhead
Grubhead
