Question about Toshiba 55H70 55" Rear Projection Television
How to replace a lamp in 55a60a toshiba tv - Toshiba 55H70 55" Rear Projection Television
Toshiba 55a60a serial 21962373
there is a problem with the power supply board seems to have failed check the power transistors u will need a qualified personnel cos this is a high voltage area even when off capacitors hold very high voltage charge you have chances of accidental electric shock
Jul 11, 2013 | Televison & Video
62HM 95 TOSHIBA. HAD THE PICTURE JUST GO BLACK THE OTHER NIGHT. I HAD A LAMP FOR IT GIVEN TO ME BY A BUDDY IT MAY BE A USED ONE NOT SURE. REPLACED BULB TV CAME BACK ON BUT PICTURE IS TO DIM TO WATCH. DONT...
These Toshiba DLP's were lemons.
There was a class action lawsuit in the US and Toshiba were forced to issue a recall on the lamps. Toshiba replaced the first lamp for free but when the lamps are burning out every 6 months at a replacement cost of $200 these tv's are expensive to run.
Sounds to me like the light engine has failed. This will probably be a $800-$1000 repair.
Scrap it and take the hit.
Nov 01, 2010 | Toshiba 62HM95 62" DLP HDTV
I have replaced my lamp unit TB25-LMP but the red
Unplug the TV, ensure the lamp door is installed and the screw is snug. Plug the TV in and wait a moment. touch and hold your finger on the power button on the front of the TV. If your TV does not power up, your ballast and power supply should be suspect. Many Toshiba DLP sets use a similar lamp design. They have been known to burst and cause a momentary short. This can knock out the power circuits which feed the lamp. If this is the case, post back for further details if you wish to repair this yourself. I hope this was of some assistance.
Mar 22, 2010 | Toshiba 52HMX94 52" Rear Projection HDTV
How do I reset the DLP lamp timer on my Toshiba 44NHM84 TV?
Hi,One way to reset lamp timer is to unplug tv wait 5 min and plug it back again.
Jan 05, 2010 | Toshiba 65HM167 65" Projection Television
Need to install a replacemen lamp in a Toshiba 62" HD DLP Projection TX. How is it installed?
What is the model number??, There are just way too may Toshiba sets to try and guess the one you have!! or try here. http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TVom.asp
Good Luck
TECHMAN.
Sep 05, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
How can I order a lamp for a toshiba 55hm66 with a lamp y66-lmp and how can I put this lamp in my tv
Check Lamp for your TV in Part Store and lamp replacement procedure would be mentioned in user manual of TV.
Jul 02, 2009 | Toshiba 50HM66 52" Television
TOSHIBA 50in rear projection. Mod# 55A60A
convergence ic 's are bad need to remove and replace chips, need soldering skills, do not attempt if you are not good at soldering and desoldering
May 16, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 55H70 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
