Question about Motorola Walkie Talkie 2-Way Radio
Cant hear on one walkie talkie - Motorola Walkie Talkie 2-Way Radio
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Posted on Jan 06, 2015
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Nov 14, 2009
eradiostore
  • 1654 Answers
SOURCE: my motorola xtr446 has an icon stuck on it
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
Posted on May 16, 2010
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
How to fix a motorola fv200?
these are one-way radios. no service, no spareparts. just trough away and buy new
Dec 18, 2013 | Motorola Walkie Talkie 2-Way Radio
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
How to find someone using a wallis talkie
Program your existing walkie talkie to a common frequency with no PL code turned on and listen for activity. If you are using a TalkAbout or other FRS radio you should hear activity on one or more channels if you are in a city.
Best regards.
Mar 16, 2013 | Motorola Walkie Talkie 2-Way Radio
Talking
See if the one radio that doesn't hear the other has a PL tone programmed into it. If both radios are not programmed to the same PL tone, then one will not hear the other. Consult your owner's manual on how to do this.
Regards,
Longshorts.
Jun 24, 2009 | Motorola Walkie Talkie 2-Way Radio
Im only able to hear out of one of my walkie talkies
Make sure you are using the same channel and privacy code as outlines in the manual for each radio.On the creen the large number is the channel and the smaller number is the privacy code.
Here is a link to the manual: http://www.midlandradio.com/comersus/store/catalog/LXT410%20Owners%20Manual%20RevH.pdf
May 06, 2009 | Midland LXT310 2-Way Radio
My walkie talkies wont transmit
Go on line. Search for the operators manual. It should give you the information you need.
Feb 06, 2009 | Motorola Walkie Talkie 2-Way Radio
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
102 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
