Question about Ovens
Pf light ikea ibs550pwsoo
Controls don't work after pf light came on
My stove will not work it always shows PF how do I fix this as nothing works
PF is most likely power failure. Nothing responds in keypad? Try setting clock. If nothing responds, your control is probably bad.
Sep 16, 2017 | Ovens
What does the message PF mean?
PF = Power Fail. Possibly damaged control board.
Dec 23, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 23, 2011 | Whirlpool Ovens
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
Indicator light says ''pf''
"PF" CODE USUALLY INDICATES A POWER FAILURE CLEAR CONTROL PANEL---RESET, CLOCK, OR TIMERS AND SET TO BAKE 350' IF EVERYTHING RESPONDS O.K. YOUR LIGHTS MAY HAVE BLINKED OR SOME OTHER POWER INTERUPTION
Jun 24, 2009 | Ovens
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Had a power failure and now getting a PF E1 error on the control panel
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Nov 22, 2007 | Whirlpool GBD307PRS Stainless Steel...
Go to PF when there is none
wshort, As long as you are sure the circuit to the oven is not the problem,such as drop in voltage, here are a couple of suggestions. Number one is that the electronic parts for this model have a five year warranty on them and you may want to call for factory service. Sometimes the connections on the main control board become loose or corroded. Try reseating them and see if the problem stops. If not I would suspect the control board power transformer behind the control board. There are two transformers, one for lights the other for the control board. The control board transformer should have the red and blue wires while the light transformer will have the black and white. The voltage could be dropping out here. Make sure that the wires to the oven terminal block are not loose or burnt. Since you are not receiving any error codes except for PF, Im not suspecting the board itself. Catriver...post back.
Dec 26, 2006 | KitchenAid KEBC278 Electric Double Oven
Ovens Logo
23 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
